What oil for my 2007 Vulcan 900? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 8 (permalink) Old 04-02-2010, 12:48 PM Thread Starter
I have a 2007 Vulcan 900 Custom and I need to change the oil. I don't have a manual and I'm wondering what oil weight I should use. Also, anyone know how many quarts of oil this bike takes when also changing the filter?
The original owner used Amsoil in it so I'm planning on continuing with that. They offer three weights 30, 40 and 50.....
Any thoughts?
Thanks!
Shawn71 is offline
post #2 of 8 (permalink) Old 04-02-2010, 12:51 PM
Hey........10/40 is the norm......some use 20/50.......but if u stick with the 10/40 all should be fine...Motor bike specific...
4 WHEELS MOVE THE BODY.....2 WHEELS MOVE THE SOUL.....
Tazlives2ride is offline
post #3 of 8 (permalink) Old 04-02-2010, 02:06 PM
TNCarters's Avatar
Service manual says 3.4 quarts (3.9 qts if completely dry). May want to go a little less until you start it and circulate through the filter, then re-check. The 900 has a tendancy to pass a bit of oil through the crankcase breather into the air filter area if its over filled.
If you want to run Amsoil a regular poster (Bob) on here in the Oil forum will direct ship to you at a good price. I'm running 40 weight in Tennessee but some think 50 weight is better for very hot climates or to quiet the moving parts a little.
Ron
Southern Crusiers, Chapter #6
2009 Vulcan 900 LT Red/Titanium
Kury Iso Grips and Throttle Lock
Cobra Guard w/Kury Foot Rests
Kawa Windshield Lowers
Scootworks Pulley
Cobra Luggage Rack
Wolo BadBoy Horn
TNCarters is offline
post #4 of 8 (permalink) Old 04-02-2010, 11:45 PM
I live in one of those very hot climates (does 110 qualify), and I have not had any problems to speak of with 10W/40, but then I do, some who are knowledgeable than myself, believe that the 20W/50 might be a bit thick for this engine, but that also is hard to prove, it is water cooled and not as prone to overheat as air cooled engines in these conditions.
As far as brand, dino or syn, you choose, I have my preference, as do others and I am not here to convert or preach to the choir or start any thread war's.
Ride Safe.
John
"I am a modern cowboy, on a steel horse I ride"
09 VN900 Classic
Big 3 +++++
Double Darkside
Last edited by Bytehead; 04-03-2010 at 12:32 AM. Reason: bad eyes need new glasses
Bytehead is offline
post #5 of 8 (permalink) Old 04-03-2010, 07:40 PM
TyHawk's Avatar
Rotella T 5-40 synthetic diesel oil is the deal. Your bike will last just as long for way cheaper.
09 VN 900 SE
TyHawk is offline
post #6 of 8 (permalink) Old 04-03-2010, 09:50 PM
kray's Avatar
As TNCarters posted, go to the Amsoil section of this forum and talk to Bob. He will hook you up with the correct oil and filter.
VROC #31005
'09 Vulcan 900 Classic turned LT
Fightin' Texas Aggie Class of '04
kray is offline
post #7 of 8 (permalink) Old 04-06-2010, 12:41 AM
I have the manual depends on temperture you can ue 10w40 10w50 20w50 i am going to use a high quality 20 w 50 it runs hard on highway.
Any thoughts?
Thanks!
Automech44 is offline
post #8 of 8 (permalink) Old 04-06-2010, 01:01 AM
ChevelleSSLS6's Avatar
I'm currently running "Kawasaki" 10-40 oil. I've been told it's bottled by Motul.
It's the dino juice, but I'm currently falling for the "don't break it in on synthetic" myth. I think car companies use the "mobil 1 factory fill" to reduce confusion though.
My theory is that the synthetic is too slippery and won't let the rings set in as quickly as would traditional oils.
With the 650R I had, I noticed smoother transmission action and the engine ran a little smoother with Amsoil. It's good stuff.
As for filters, Amsoil filters are MADE by Wix, but ARE NOT Wix filters. Amsoil uses a better filter media. I'm running a Hastings filter (I crossed it with the 'long' Purolators) as I like Hastings/Baldwin. You can get them at some parts stores or industrial supply houses like Granger.
2007 Ninja 650R traded in and missed
2009 Vulcan 900 Classic current Kawi
900cc=55 cubic inches
Is there a Gadget page for us 900 owners???
Vulcan 900 "oily air filter" fix
Get 3-4 feet of tranny line from parts store that's the same ID as the stock vent line. Attach to jug, route hose up to bottom of fuel tank around wires and back down to airbox, cut off excess (leave a little slack so wires are NOT under tension) and attach to airbox. Reinstall everything.
ChevelleSSLS6 is offline
