Sputtering/ no power in 2-5 gear need help - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 22 (permalink) Old 05-03-2013, 08:56 AM Thread Starter
05gtiguy's Avatar
I have a 2012 with 2k miles on it. I have never had an issue with the bike, until today. I was riding down the freeway and it started sputtering almost like it wasn't getting any gas. Then it stalled, when I started back up it idled perfect, first gear perfect but as soon as I shifted to second gear and gave it gas it started sputtering, backfiring and died out again. I pulled off again and turned it off waiting a few minutes and then tried again with the same results idle and first gear work perfect but as soon as I shift to any other gear it sputters, lacks any power, and just backfires. The f1 light comes on only after I shift into a higher gear. It will let me ride like nothing is wrong in 1st gear no matter how hard I hit the throttle but as soon as I switch to 2nd or 3rd I experience the issue. Any idea's what this might be? Bike has 3inch straight pipes, a barons big air kit, and power commander.
05gtiguy is offline
post #2 of 22 (permalink) Old 05-03-2013, 12:03 PM
bosco's Avatar
Do you have a service manual? If so, check out the troubleshooting section, but with your fuel mgmt system installed you'll have to take that into consideration.
Without testing fuel pressure, my guess would be along these lines a fuel pump, fuel filter, bad fuel (water), fuel line obstruction. After these it could be the power cmdr (you could test by removing), and finally the ECU.
I am surprised it does not cut out during first gear acceleration. Hope you find your problem.
2010 900 Classic
bosco is offline
post #3 of 22 (permalink) Old 05-03-2013, 12:42 PM
silenthill's Avatar
Bad gas, was it laid up for the winter? Too much Stabil?
2009 VN900 Classic LT.
Nova Scotia, Canada.
Cobra luggage rack.
Kuryakyn Grand Tourer luggage bag.
Kuryakyn air filter cover.
170/80/15 Metzler rear tire.
Fire and Ice passenger floorboards.
Stage 2 debaffle (screens left intact).
silenthill is offline
post #4 of 22 (permalink) Old 05-03-2013, 12:57 PM
ErnieC's Avatar
Check the hoses on top of the cylinders, I had a lot of backfiring etc one time after 1st, I found the vacum hose on top of the cyclinder had come off
2006 900 LT
Easy Mods
Crash Bars,Rear Tail Lights in Bags,Cooler bag on Sisy Bar,hand made Bag on Windshield,Wally world Cup Holder,Lower Shields,Gas Tank Bib,Baron Front Pulley
**Bikers are hard to find, Bikes are a Dime a Dozen**
My Second Hobby:
Here is another Hobby of mine model boats
ErnieC is offline
post #5 of 22 (permalink) Old 05-03-2013, 01:11 PM
I agree with BOSCO about removing the PC just to see if that's the problem. You might check the code that's now stored in the ECU to see why the FI light was coming on. I'm going to guess it's the throttle position sensor, but it's only a guess.
Sojourner is offline
post #6 of 22 (permalink) Old 05-03-2013, 01:29 PM
As Sojourner said, remove power commander and try again.
The FI light may be coming on due to stall. Removing PC may clear FI light.
sfair is offline
post #7 of 22 (permalink) Old 05-03-2013, 01:30 PM
SWVA_08V2k's Avatar
First thing I would do is get some fresh fuel in there if it has been sitting of a while. (doubt it is because of winter since you are in Hawaii)
Second thing I would do is check the charging system, low power going to the ECU and Fuel System can cause some crazy symptoms.
Third for me would be the PC. I can't help it but I tend to follow the aftermarket added parts before I suspect factory components.
A question for the 900 gurus, does the 900 have a shifter position sensor like the V2Ks. The V2Ks timing changes depending on what gear it is in. The reason I ask is because I find it odd that it doesn't cut on in 1st.
SWVA_08V2k is offline
post #8 of 22 (permalink) Old 05-03-2013, 01:41 PM
whoaru99's Avatar
I third or fourth the recommendation to remove the Power Commander before any further troubleshooting.
whoaru99 is offline
post #9 of 22 (permalink) Old 05-03-2013, 02:40 PM
Daboo311's Avatar
I'm thinking if bad fuel or water in gas, you would not be able to run fine in 1st.
With the low miles you have on it, it is a kit/pc problem. This is one of the reasons I don't care about making these types of additions to stock bike.
Daboo311 is offline
post #10 of 22 (permalink) Old 05-03-2013, 04:47 PM Thread Starter
05gtiguy's Avatar
Thanks so much for all the help. The thing that throw me is it works fine at idle and in first gear. I ride the bike almost everyday, in fact before it did this I had been riding the same morning without any issue, then in the afternoon this happened about ten min into my ride. I did check all the hoses and everything there looks fine. When I removed the PC I thought that fixed it as i was able to somewhat ride but I got to 3 gear and same issue, and now it's doing the same thing in every gear other then first again. As far as gas it's on half tank and was put in from the same place I always go. I go through a tank in about 2-3 weeks. I don't have a battery tender so checking that myself is out right now. Any other thoughts?
2012 Vulcan 900
Barons BAK
Hard Chrome Big Straights
Power Commander
05gtiguy is offline
