Valve Adjustment - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 08-23-2008, 08:24 PM Thread Starter
rust47's Avatar
Valve Adjustment
At 15000 miles the valve adjustment is supposed to be checked. Has any one had their valves need any adjustment at this mileage?
2007 Vulcan 900 Classic LT
Cobra Dragster Pipes
Cobra Fi2000r Processor
Custom Paint
rust47 is offline
post #2 of 10 (permalink) Old 08-25-2008, 01:21 PM
blunoz cruiser's Avatar
Cool no adjustment req'd
I'm not a motorcycle mechanic but, my understanding with the VN900 having hydraulic lifters that there was no requirement to perform any maintenance on the valves or valve clearance. A Dealer might be your best source for the "Warranty Answer".
blunoz cruiser is offline
post #3 of 10 (permalink) Old 08-25-2008, 08:03 PM
I am pretty sure they are not hydraulic lifters. And yes check your valves to see if they need adjustment. It is recommended to do it every 15k so do it then.
spencea15 is offline
post #4 of 10 (permalink) Old 08-26-2008, 06:57 AM
Talking Overhead Cam
Hey guys,
The VN900 has overhead cams so, no lifters.
Some of the big Jap cruisers, Yamaha for one are using push rods now (backwards step) to keep the motor shorter for styling reasons but the
VN900 is SOHC. Definitely get clearances checked as recommended
or noise and potential damage are likely.
Paradox is offline
post #5 of 10 (permalink) Old 08-26-2008, 01:17 PM
Ooops
Sorry guys, my mistake. I've only got around 8K on my machine so haven't reached that section of the manual. Guess that's what's good about the forum.
Blunoz Cruiser
06 VN900 LT
post #6 of 10 (permalink) Old 09-02-2009, 05:21 PM
justinmccurdy25's Avatar
i have the same bike, i checked mine at 14000 miles and i had to replace 4 shims, 2 on the front head and 2 on the rear. there was only .05ths of a change but i still brought them back into spec
justinmccurdy25 is offline
post #7 of 10 (permalink) Old 09-03-2009, 11:00 AM
900 customs supposedly have hydraulic tensioners...so it shouldnt got out of spec...however it needs to be checked to make sure
2008 Candy Lime Green VN900C
Cut/DeBaffled OEM Pipes
Ram Air Mod
Lowered 2"
Saddlemen Seat
9" Apes
thehun is offline
post #8 of 10 (permalink) Old 09-03-2009, 03:49 PM
The 06 Classic has one over head cam per cylinder, with solid cam followers (lifters) and uses shims for adjustment. They do indeed need to be adjusted per the owners manual schedule to allow for cam, follower, and valve stem wear. If not adjusted the clearance will eventually be gone, the valve will not close tightly, the valve will leak, allowing extremely hot compustion gases to blow by, burning the valve or seat or both, to the point they will need to be replaced.
ikindoit is offline
post #9 of 10 (permalink) Old 09-04-2009, 12:48 AM
Jace Bror's Avatar
They have hydraulic cam chain tensioners. So thats just the chain. The valves are on their own. You still have to check the tolerances and change out shims. Too bad they couldn't have made it like 250 ninja where it is a matter of lossening a keeper nut and adjusting a screw. Then you don't have to run around looking for shims.
eLi
South of the Twin Cities.
Ride the river.
'07 900 Classic "turned LT"
Cobra Fi2000
Kury HyperCharger
Metzeler WhiteWalls
Speedo fixer in back (170)
Fuel Gauge resistor
'00 Vulcan 750 (SOLD)
'73 Honda CL350
Jace Bror is offline
post #10 of 10 (permalink) Old 09-04-2009, 07:52 AM
dang...and valve adjustments are an arm and a leg...my cb750 takes about 15 min for me to change valves.
Ram Air Mod
Lowered 2"
Saddlemen Seat
9" Apes
thehun is offline
