Broke grease fitting on bottom of bike! - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 187 (permalink) Old 09-10-2009, 03:50 PM Thread Starter
Jeep Pirate's Avatar
First, does anyone know the name of the idiot engineer who made the lowest point on the bike a grease fitting into cast aluminum? If I can find him, he is due an ass whooping!
Second, after someone has gone over a speed bump and thereby ripped this silly fitting out of its casting, what do you do? I assume I could spend an astronomical amount of money at a repair shop having the whole rocker arm replaced. But honestly, I don't really want another rocker with the same stupid design flaw. I am thinking of trying to re-tap the hole and just put in a worm screw plug. Any advise would be great. Maybe some of you guys with newer models can tell me if they fixed this on your bike. Mine is an '07. I know they fixed the phillips head screw on the air filter on the newer bikes by making it an allen head.
'07 VN900 Classic
Horsepower is an illusion.
Jeep Pirate is offline
post #2 of 187 (permalink) Old 09-10-2009, 04:28 PM
Rollingbones's Avatar
I know there's two of them down there and I believe the front one on mine is gone as well (and I'd be willing to bet that more people have lost it than have it). Hmmmmm... time for a google search on this matter...
Mark...Rollingbones
2011 Harley Road King FLHR
2008 Vulcan 900 Classic (Sold)
American Legion Riders Post 383
Patriot Guard Riders
Sacramento Metro Fire CERT
West Fair Oaks Neighborhood Watch
________________________________
Ride Long and Prosper!!!
Rollingbones is offline
post #3 of 187 (permalink) Old 09-10-2009, 08:24 PM
Helek_52's Avatar
Year/Make/Model: 2009 Kawasaki Vulcan 900 Custom
Displacement/CC's: 900
Color: Black
I'm with you guys. The first time i noticed the fittings down there i thought "Now that's stupid. Any big bump or curb and those are history."
I guess if you can't back them out, you'd have to drill and tap. Bummer.
Keep the Shiny Side Up!
'09 900 Custom SE on the Darkside
"Not all those who wander are lost." J.R.R. Tolkien
Helek_52 is offline
post #4 of 187 (permalink) Old 09-10-2009, 08:55 PM
Usually, the zerk is just knocked out and not broken off - very common (unfortunately). Go to the local parts store and pick up some metric replacement zerks - then flush out the fitting till fresh grease oozes out everywhere!. Then, remove the zerk and replace with a allen head replacement screw that fits flush in the hole. These are available at many hardware stores - Ace included. Problem solved! When you need to add grease - wash, rinse, repeat!
nedley is offline
post #5 of 187 (permalink) Old 09-10-2009, 11:41 PM
Usually the nipple just broke off. Remove the threaded portion with an EZ Out. I pulled all my grease fittings and replaced with a metric set screw ( I think that they are 4mm). The set screw should sit flush with the casting. When you need to grease the bearings, jut replace the screw with a zerk, grease the bearing, then replace the set screw.
LabGuy is offline
post #6 of 187 (permalink) Old 09-11-2009, 07:20 AM
silenthill's Avatar
Now that is some good advice! Thanks guys!
2009 VN900 Classic LT.
Nova Scotia, Canada.
Cobra luggage rack.
Kuryakyn Grand Tourer luggage bag.
Kuryakyn air filter cover.
170/80/15 Metzler rear tire.
Fire and Ice passenger floorboards.
Stage 2 debaffle (screens left intact).
silenthill is offline
post #7 of 187 (permalink) Old 09-11-2009, 08:21 AM
Helek_52's Avatar
Color: Black
Really great idea. Thanks guys.
Helek_52 is offline
post #8 of 187 (permalink) Old 09-11-2009, 04:18 PM Thread Starter
Thanks for the advise guys. But I do still have one issue. My front and rear fittings are okay and I can do the set screw swap easily enough. However, my middle fitting is the one that has been ripped out. From what I can tell, the threads in the aluminum casting broke completely out of the hole because the zerk is steel and therefore it's threads didn't break first. The old fitting will just slide in and out of the old hole now. I am wondering if there is enough depth to the hole to run a tap set into so that I can go up a size of zerk fitting?
'07 VN900 Classic
post #9 of 187 (permalink) Old 09-12-2009, 07:55 PM
teamsunbelt's Avatar
JP, Me Too!
I lost mine on a speed bump. At my last service, the tech said that when the Zerk broke, it toke metal with it. It would have to be drilled and tapped, and new zerk, and fill in the difference with JB Weld. His price, $75 per hour. And this will never gaurantee that it will not happen again. This is the down fall of buying bikes from a place that big guys weigh 150.
You could look at one of the lowering kits, if you want a little lowerer stance, plus they have sealed joints, I think.
As soon as I get an EZ Out set, I am going to try one of the above fixes.
'08 VULCAN 900 Custom
GenMar Risers
Mustang 2 Up Seat / Mustang Tank Cover
Cobra Back Rest w/ Plate
Cobra Luggage Rack
Willie & Max Revolution Bags
Memphis Shades Windshield
Kuryakyn Iso Grips w/ Throttle Boss
Smoked Signals
Dually Rear Pegs
teamsunbelt is offline
post #10 of 187 (permalink) Old 09-14-2009, 01:59 PM
tcrider's Avatar
type of grease
Hi, I'm trying to check the grease on this fittings and I have a can of "hevron High load carrying capacity Ultra Duty grease EP NLGI 2 ". I'm almost sure that it 'll OK, but just want to make sure.
If anybody knows for sure please let know. \
Thanks.
Likin'the forum. Kind of new still ...
tcrider is offline
