Winterizing the bike - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 01-05-2013, 04:01 PM Thread Starter
dwhit's Avatar
Thumbs up Winterizing the bike
Just curious about how long a bike can sit in a covered garage away from the elements without winterizing - charging battery, etc. My thoughts are that even though its cold I can probably get a ride in at least once every three weeks even short 15 mile runs. I know in march I'll be able to ride it more than once every three weeks so I have 2-3 months of possible storage. Can you leave it for three months with occasional start ups without winterizing?: )
dwhit is offline
post #2 of 7 (permalink) Old 01-05-2013, 04:47 PM
SteveJB's Avatar
Year/Make/Model: 2007 VN900 Custom
Displacement/CC's: 903 cc
Color: Candy Plasma Blue
"Occasional startups" should include letting it run long enough to get the engine up to normal running temp. I'd still use a battery tender though. Idling may not be enough to keep the battery charged.
SteveJB is offline
post #3 of 7 (permalink) Old 01-06-2013, 04:15 PM
I would do all above plus filling the tank and add a fuel stabilizer. As the fuel level drops when you run the bike, the mixture will prevent any fuel component issues. Gasoline is parishable.
mdsimon80 is offline
post #4 of 7 (permalink) Old 01-06-2013, 05:49 PM
Banned
put in about a third a can of seafoam per full tank of gas, if you can put the battery on Battery Tender Plus 1.25amp
Vulcan_tom is offline
post #5 of 7 (permalink) Old 01-06-2013, 07:03 PM Thread Starter
dwhit's Avatar
thanks, all good suggestions but the tender will be a problem as its kept in a public garage with no electric outlet so i will have to remove the battery each time, i'm trying to avoid that but may not be able to. can you drive it with the fuel stabilizer in it?
dwhit is offline
post #6 of 7 (permalink) Old 01-07-2013, 05:23 AM
Banned
Yes
post #7 of 7 (permalink) Old 01-07-2013, 11:09 AM
All those things are good. You also have to strike a balance in "short" startups. Dependent on your storage facility temperature and if short startups get things somewhat hot as opposed to hot enough, than you can create moisture buildup that can be trapped in the exhaust system and promoting corrosion/rotting.
Denis is offline
