Buffles removed and popping on decel Need Dobeck or Cobra FI2000R - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
post #11 of 25 (permalink) Old 12-18-2012, 05:31 PM Thread Starter
OK, I did start the engine without the blue plug. I noticed a bit of pressure from the cylinders at the end of the hose and I decided to place a 1/8" hole on the blue plug.
Started the engine and there is a small air exhaust now from the blue plug's hole.
I will ride the bike tomorrow and let you know.
diamondhill is offline
post #12 of 25 (permalink) Old 12-18-2012, 06:19 PM
Collinba's Avatar
Here's a thread with some pictures.
http://www.kawasakimotorcycle.org/fo...-900-pics.html
No need to put a hole in the plug.
2010 Classic LT
Collinba is offline
post #13 of 25 (permalink) Old 12-18-2012, 07:26 PM
I believe you may have plugged the hose coming from the engine case. You should really trace the two hoses to their destinations to be sure.
Sojourner is offline
post #14 of 25 (permalink) Old 12-18-2012, 07:44 PM Thread Starter
Yes, that hose is in between the air box and an air sensor or solenoid and it T's off from there to the 2 hoses on top of each cylinder. See the link from the above answer from Collinba. And I put that small hole in the plug so the residual mixture will not build up inside the system. Thanks all for your help.
Next thing on my list is the 34 tooth pulley from Cruiser Customizing. $160 shipped.
post #15 of 25 (permalink) Old 12-19-2012, 05:10 AM
Frenchy's Avatar
About marbling, couldn't we just plug the hose, using a marble or anything else that could fit, way further up?
Or just plug where the hose starts getting rid of the hose altogether?
I am thinking about installing an homemade air intake following jeep pirate excellent example and also redirecting the crankcase breather in a proper manner.
2007 900 Classic
_________________
Mods:
Kissan signal minder
Cobra FI2000R
Kuryakin ISO grips
GiPro gear counter
No name tach.
Fiamm Air Horn
National Cycle HD windshield
Saddlemen Explorer seat
Home made backrest
Vance & Hines pipes
Stator replaced: yes, once at 28k
Frenchy is offline
post #16 of 25 (permalink) Old 12-19-2012, 06:24 AM
Collinba's Avatar
That's the idea. I used a yellow wire connector - fits perfectly.
2010 Classic LT
Collinba is offline
post #17 of 25 (permalink) Old 12-19-2012, 07:28 AM
Frenchy's Avatar
Ok, but what is a "yellow wire connector" ?
2007 900 Classic
_________________
Mods:
Cobra FI2000R
Kuryakin ISO grips
GiPro gear counter
No name tach.
Fiamm Air Horn
Home made backrest
Vance & Hines pipes
Frenchy is offline
post #18 of 25 (permalink) Old 12-19-2012, 07:50 AM
You can go as far as removing all the hoses then install rubber caps on all the open nipples (6 each). Leave the solenoid wired up or you'll get a warning light on your gauge cluster.
post #19 of 25 (permalink) Old 12-19-2012, 09:13 AM
Administrator
MN-Rider's Avatar
Displacement/CC's: 1800
Color: Pearl White
Jeff, Twin Cities, MN
Please add your bike info to your profile (User CP>top right>edit your details. If mobile,exit enhanced mobile view)
MN-Rider is offline
post #20 of 25 (permalink) Old 12-20-2012, 12:52 AM
Frenchy's Avatar
Thanks for this very graphic answer, I can't go wrong with that
2007 900 Classic
_________________
Mods:
Cobra FI2000R
Kuryakin ISO grips
GiPro gear counter
No name tach.
Fiamm Air Horn
Home made backrest
Vance & Hines pipes
Frenchy is offline
