Throttle Body Secondary Plates - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 14 (permalink) Old 11-30-2012, 12:44 PM Thread Starter
Strompilot's Avatar
I didn't want to hijack the previous thread regarding the air intake mods, so I decided to to a separate thread.
It was mentioned about removing the secondary throttle body plates (butterflies) to improve performance and engine response. My question is, what else do you need to do after removing those plates? FI box, different intake, etc.? And after removing those plates, besides improved engine response, does it smooth the engine out some at higher speeds and what does that do to your gas mileage.
Final question, what is the link to performing this mod?
Thanx in advance.
'09 650 VStrom
Strompilot is offline
post #2 of 14 (permalink) Old 11-30-2012, 02:40 PM
BOTM Winner, October/2012
417vulcan's Avatar
You dont have to do any other mods. The only difference i noticed was "snappier" throttle response.
Sent from my DROID RAZR using Motorcycle.com Free App
James
2009 Vulcan 900 Custom
Mods: Freedom Performance exhaust, Thunder Mfg Tornado Intake, Cobra Fi2000R and alot of chrome goodies
417vulcan is offline
post #3 of 14 (permalink) Old 11-30-2012, 02:42 PM
bosco's Avatar
Here you go.... link to the mod
Throttle Plate Mod
Page 7 has pics of the mod. It's a very easy mod, takes just a few minutes. Just take your time removing the screws.
2010 900 Classic
bosco is offline
post #4 of 14 (permalink) Old 11-30-2012, 07:09 PM
Thanx in advance.
I found that after removing the plates the bike would go flat for a moment when I cranked open the throttle. I figured this was due to the inrush of air and an ECU that still thinks the secondary plates are still there. I added fuel to that area (RPM & throttle position) and the problem went away. In my case removing the plates was in conjunction with adding aftermarket pipes, air kit and a PCV.
Sojourner is offline
post #5 of 14 (permalink) Old 12-01-2012, 10:39 AM Thread Starter
Strompilot's Avatar
I accessed the link, and it looks like a pretty straightforward, simple job. If I don't like the result, I hope it's just as easy to reverse the procedure and put the plates back in. But I won't do any of that until next Spring, so I"ve got lots of time.
'09 650 VStrom
post #6 of 14 (permalink) Old 12-01-2012, 10:40 AM Thread Starter
Strompilot's Avatar
I'm not sure what you mean by this--adding fuel to that area. Could you explain?
'09 650 VStrom
post #7 of 14 (permalink) Old 12-01-2012, 11:53 AM
The Power Commander lets you add or subtract fuel in individual cells laid out as a grid from zero throttle to 100% throttle, from idle up to redline. It felt like the bike was flat when I would go to 50% throttle at a relatively low to mid RPM. Adding fuel to the cells in that area of the grid took the problem away. Since then I've added the Autotune module which automatically adds or subtracts fuel based on what the O2 sensor is telling it. The problem hasn't returned.
post #8 of 14 (permalink) Old 12-01-2012, 05:51 PM
chi-rider's Avatar
+ 1 on the snappier throttle from this mod. My understanding is that the restrictors make the airflow less prone to big changes caused by bumps in the road, etc giving you smoother overall throttle feel. Course lots of us don't want it smoothed out we want the throttle to crack when we hit it. It's an easy mod that's easily put bak if you don't like it.
Chi
2010 VN900 Classic-Blue
______________________
Cobra Standard Sissy Bar with Chrome insert
Baron Crash Bars
Kuryakyn ISO Grips
Kuryakyn ISO Highway Pegs
Kuryakyn Mini Silver bullet brake lights
Scoot Works Phat Riser II's
Arlen Ness Scalloped Big Sucker
V&H Pro Pipe
V&H Fuelpak
Saddlemen Profiler seat
Barnet and Galfer Stainless control cables
Cobra Passenger floorboards and bag supports
Chilhowee Leather bags
American Biker Tool bag
Chrome Breather filter
chi-rider is offline
post #9 of 14 (permalink) Old 12-01-2012, 05:53 PM
chi-rider's Avatar
And also, i did have to add fuel to my v&h fuelpak at the 3500 rpm range. Works like a top now.
Baron Crash Bars
Kuryakyn ISO Grips
V&H Pro Pipe
V&H Fuelpak
post #10 of 14 (permalink) Old 12-01-2012, 05:59 PM
cheapdutchguy's Avatar
Did same on my v2k. Nothing else required. Just better throttle response.(read spins rear tire)
2006 VN2000 Classic Lt
cheapdutchguy is offline
