Sparking sound from front cylinder - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 11-25-2012, 09:24 AM Thread Starter
Send a message via Skype™ to Mobasher
Question Sparking sound from front cylinder
I have Vulcan 900 classic Lt 2011. I have just done 2000 miles on it and recently it developed sparking sound in front cylinder. I have changed spark plugs, checked plug lead and adjusted teppits but the trouble persist. The bike performance is otherwise fine. Can anybody help with diagnose.
Mobasher is offline
post #2 of 10 (permalink) Old 11-26-2012, 09:24 AM
mcdonaldjg's Avatar
It could be the fuel injectors that you hear clicking.
Here is one thread on subject. Odd noise...is it normal?
mcdonaldjg is offline
post #3 of 10 (permalink) Old 11-26-2012, 09:55 AM Thread Starter
Thanks, it's not fuel injection click. The sound is heard even on idling and at infrequent intervals.
Mobasher is offline
post #4 of 10 (permalink) Old 11-26-2012, 11:26 AM
Since it runs fine it may be a small exhaust leak at the exhaust flange. I've read in this forum where some folks have experienced the acorn nuts loosening. Good luck.
2008 Classic LT
GearDoctor is offline
post #5 of 10 (permalink) Old 11-26-2012, 12:25 PM Thread Starter
Smile Sparking sound in front cylinder
Thanks, I will check this over the weekend
Mobasher is offline
post #6 of 10 (permalink) Old 11-26-2012, 02:45 PM
Could it just be the AIS and you're just now noticing it?
2013 HD Super Glide Custom
Infinite_Day is offline
post #7 of 10 (permalink) Old 11-26-2012, 05:03 PM
mcdonaldjg's Avatar
What Is AIS ?
post #8 of 10 (permalink) Old 11-26-2012, 06:21 PM
SteveJB's Avatar
Year/Make/Model: 2007 VN900 Custom
Displacement/CC's: 903 cc
Color: Candy Plasma Blue
Air Induction System?
SteveJB is offline
post #9 of 10 (permalink) Old 11-26-2012, 07:33 PM
Haven't had my Vulcan long but noticed a clicking above and behind the air box near the front cylinder. Did some research and found that it's a system the puts air into the exhaust to burn excess fuel (AIS). There is an actuator in the system that opens a valve and that is the clicking I was hearing. It is irregular and may be what you are hearing too. It's normal if so. Somebody may be able to add to this with more knowledge than I have.
post #10 of 10 (permalink) Old 11-27-2012, 01:14 PM
bosco's Avatar
Ever since I installed my Air Intake System I hear alot more sounds. Injector ticking is more defined, as well as, what you mention above with the AIS. Under accelerating throttle seems I even hear the jugs sucking air like my compressor. I think the stock airbox used to insulate these sounds alot more.
2010 900 Classic
bosco is offline
