Tachometer installation help on '11 VN 900 - Page 3 - Kawasaki Vulcan Forum : Vulcan Forums
post #21 of 39 (permalink) Old 11-10-2012, 12:25 PM Thread Starter
http://www.ebay.com/itm/170909533755...84.m1439.l2649
This is the brand new adapter and I did wired up as specified.
Thank you again
diamondhill is offline
post #22 of 39 (permalink) Old 11-10-2012, 01:29 PM
Looking at that adapter, it seems like it has 4 wires. Is this true?
Describe the instructions for installation.
Also, you can connect the tach signal wire to one of the coil negative terminals to see if the tach actually works...it just will read incorrectly.
sfair is offline
post #23 of 39 (permalink) Old 11-10-2012, 02:55 PM Thread Starter
post #24 of 39 (permalink) Old 11-10-2012, 03:35 PM Thread Starter
Tach works without the adapter, just half the RPM. Green to one black wire coil.
I owe you one. That means I need a different adapter (for a metric bike)? Or I can build my own like I've seen on the site.
Any suggestions from someone is appreciated. Thank you
Miller time. Stay thirsty my friends.
post #25 of 39 (permalink) Old 11-10-2012, 04:04 PM
Take a look at this:
http://www.gadgetjq.com/tach_install.htm
Note: diodes must be reversed to what is shown in diagram.
I am not sure what you have there, but it does not seem to work.
sfair is offline
post #26 of 39 (permalink) Old 11-10-2012, 04:14 PM Thread Starter
This is specific for Harley in description... so now we know they can not be used for metric bikes.
Thank you again
post #27 of 39 (permalink) Old 11-10-2012, 05:03 PM
You are very welcome.
Post back if you have any more problems.
sfair is offline
post #28 of 39 (permalink) Old 11-10-2012, 06:22 PM
Thank you again
I'm not so certain. The Baron adaptor works on both HD and Metrics. With the Baron no tacho wires go to the coil. The green tacho wire goes to the green adaptor wire. From the adaptor the yellow & blue wires go to negative side of coils (one each).
I had a look on ebay and that adaptor comes with 3 leads. If you have a 4th lead then that is an optional resitor to help with needle bounce (according to the description).
2008 VN900 Vulcan Classic
2014 Triumph Thunderbird LT
fawlty99 is offline
post #29 of 39 (permalink) Old 11-10-2012, 07:33 PM Thread Starter
With any adapters no tach wires go to the coil. The problem with these adapters is that they are bulky and hard to hide. That is the reason I got this slim one( just 3 wires and no box) on ebay that did not worked out for me. But I will build my own next week and sell this one on ebay for the Harleys.
post #30 of 39 (permalink) Old 11-11-2012, 02:26 AM
Post back on how you get on. Good luck.
fawlty99 is offline
