Need Help Please-issue with turn signals - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 14 (permalink) Old 11-05-2012, 03:21 PM Thread Starter
wildirishman64's Avatar
Year/Make/Model: 2008 Kawasaki Vulcan
Color: titanium and white
So here is my problem, replaced stock turn signals with a great looking chrome bullet. All my lights, 2 spotlights, headlamp and running turns work up front. I blew something on the bike and replaced the appropriate fuses. My rear turn lamps will not work nor will the front ones either. Meaning, they will not blink. I have checked fuses, connections under seat, and lamps. They all look good. I'm replacing lamps even though the filaments look good. I replace the turn signal relay with 25 amp two plug automotive so please jump in. It should be noted that my red tail light works along with the license plate light? crazy
2008 Vulcan 900 LT From the Bluegrass State
USAF 85-89
Patriot Guard
Rolling Thunder 2011
Current Mileage 59,900
Batwing
Badges removed
Show Chrome gone and Pipes cut down, 3 inch baffle installed sound fanfreakintastic
Be Irish or Go HOME
wildirishman64 is offline
post #2 of 14 (permalink) Old 11-05-2012, 04:32 PM
My guess would be that the replacement flasher you used is not compatible or perhaps the switch at the bars? I'm no motorcycle tech, though.
2013 HD Super Glide Custom
Infinite_Day is offline
post #3 of 14 (permalink) Old 11-05-2012, 05:29 PM
rick's Avatar
Do they light up and just dont flash, or do they not light at all? If they all light when you turn on the signal, guess either wrong or bad flasher. sometimes even new can be defective. If they are lighting, is it the bright side if a 2 filiment bulb?
rick is offline
post #4 of 14 (permalink) Old 11-05-2012, 05:31 PM
rick's Avatar
Also, if the new signals are LEDs, you need a specific flasher for those, or load equalizers on them. A standard flashing will think the bulbs are blown.
rick is offline
post #5 of 14 (permalink) Old 11-05-2012, 07:34 PM
I would also recheck the connection to the lights, especially the grounds.
Sent from my Desire HD using Motorcycle.com Free App
2000 VN800B
Phil in Maine is offline
post #6 of 14 (permalink) Old 11-06-2012, 02:50 PM Thread Starter
Yes the front two light up, these are the ones from ebay, nice bullet style. the stock rear turns don't flash and I replaced the bulbs and cleaned the switch on handlebar with cleaner, making sure contact was good. I have three wires coming out of the front, two wires are designated flash and running, I have my ground and not sure where is goes. I've tried to ground it to the chrome housing in between the nut and bolt, but still no difference. I install a heavy duty 25 amp relay (automotive) and it didn't flash either? Thanks for the help
USAF 85-89
Patriot Guard
Batwing
Badges removed
Be Irish or Go HOME
post #7 of 14 (permalink) Old 11-06-2012, 04:10 PM
Bear2123's Avatar
You say "bulbs". Are they LED or standard?
Bear2123 is offline
post #8 of 14 (permalink) Old 11-07-2012, 08:16 AM
Did you cut the wires to install them? If you have the wires hooked up backwards they may not flash. I checked as I wired them up before I made the permanent connections when I put LED's on the back. I wired the first one backward and when I checked it it did not flash. Switched the wires around (I mean hot and ground - not left and right signal wires) and they flashed.
post #9 of 14 (permalink) Old 11-07-2012, 02:19 PM
Vulcar's Avatar
Be careful with the wiring for turn signals. I once hooked up an alarm to get the turn signal lights to flash when armed, etc. The problem was I hooked them up backwards and burnt out my stator which had to be replaced. Expensive mistake to say the least.
Like a earlier post suggested be sure you are not mixing LED's and bulbs without proper loads.
Have you tried measuring any voltages?
Good luck.
Vulcar is offline
post #10 of 14 (permalink) Old 11-07-2012, 02:38 PM
If anybody is switching to LED's this http://www.customled.com/products/fl...youtRegion1LYR
electronic relay is a plug and play replacement for the OEM one. Worked great for me.
