Need Help Please-issue with turn signals - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
post #11 of 14 (permalink) Old 11-09-2012, 04:16 PM Thread Starter
wildirishman64's Avatar
Year/Make/Model: 2008 Kawasaki Vulcan
Color: titanium and white
They are bulbs. (Halogen), I know they blink when I first put them on. I did notice that they are a single filament. In the front I've read that they should be two? Also, I took one of the wires from the new light off and the rear now works crazy?
2008 Vulcan 900 LT From the Bluegrass State
USAF 85-89
Patriot Guard
Rolling Thunder 2011
Current Mileage 59,900
Batwing
Badges removed
Show Chrome gone and Pipes cut down, 3 inch baffle installed sound fanfreakintastic
Be Irish or Go HOME
wildirishman64 is offline
post #12 of 14 (permalink) Old 11-09-2012, 06:14 PM
Post back with make and model number of signals that you are trying to install.
A link would be nice, too.
Post back.
sfair is offline
post #13 of 14 (permalink) Old 11-10-2012, 07:43 AM
Vulcar's Avatar
Yep, since the front are used as turn signals and running lights, they will have two filiments. The rear are just flashers and will have only one filiment. Normaly due to bulb type, one will not install in the other because the pins are spaced different on the bulbs.
Like Sfair mentioned give us some numbers and pics if available.
2007 VN900 Classic LT (Dragon Theme)
Cobra- Pipes, FI2000, Passenger Floor boards, Engine guard and luggage rack.
Memphis Shade with 9" windshield.
Mustang seat
Chrome covers for neck, radiator, Rear brake Master Cylinder, and regulator.
Kuryakan Grips
RC Components Nitro Chrome wheels w/ Night Dragon Tires.
Çobra Power Flo breather
Vulcar is offline
post #14 of 14 (permalink) Old 11-10-2012, 07:57 AM
Collinba's Avatar
Sounds as though you don't have a ground. If you replaced the turn signal with an automotive one you likely need to ground it. When I replaced mine with the Single Minder relay to automatically turn the flash off after 20 seconds they provided a sparate ground wire that I had to install as the OEM relay does not require a ground wire. There is a good ground point on the right side under the battery cover they have already installed a couple of ground wires.
2010 Classic LT
Collinba is offline
