Motorcycle Jack. building an adapter. - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
post #1 of 12 (permalink) Old 01-03-2017, 03:31 PM Thread Starter
Year/Make/Model: 2008 V900 Custom
Displacement/CC's: 900
I have this motorcycle jack pictured below.
The pads on the jack are barely long enough to get across the frame and I can see that the the engine hangs below the frame rails. This is not ideal.
I have some round tubing laying around and I have decided to fabricate a cradle to support the frame rails.
Have any of you done this?
Any pictures of the finished product?
westcoastkevin is offline
post #2 of 12 (permalink) Old 01-03-2017, 06:03 PM
alwhite00's Avatar
Year/Make/Model: Nomad
Displacement/CC's: 1500
Color: red
I bought a Idaho jack adapter and couldn't be happier. Money well spent. IMO
alwhite00 is offline
post #3 of 12 (permalink) Old 01-03-2017, 09:29 PM Thread Starter
Thanks for the reply. I never heard of that. That is clever. Does it fit the 900 frame too or just the bigger bike?
Well, after dinner, I knocked one out.
I split a piece of tubing lengthwise and rounded all of the edges. (Less likely to scratch up the frame.)
I fitted the tubing to the frame and notched it to clear obstructions where needed.
I tack welded it up and checked the fitment. It is a good fit on the frame and I expect it to be rock solid. As a side note, the lower frame rails are not parallel. They are wider at the back by about half an inch. (at the locations I was measuring.)
Then I called it a night.
The jack comes with risers which are located with some pins. I like that feature so I will copy it with my adapter.
Tomorrow (or later in the week), I will:
1. finish welding it up.
2. make a few pins for my jig to make it work the same way as the risers for the jack.
3. make a couple of clamps with the left over tubing to clamp the frame into it.
4. paint it or maybe spray the contact surface with some of that rubberized coating in a can.
ID:	180426   Click image for larger version
post #4 of 12 (permalink) Old 01-04-2017, 06:29 AM
TexasZ's Avatar
Awesome job on making the adapter! Bet ya could sell a few if you made some more.
TexasZ is offline
post #5 of 12 (permalink) Old 01-04-2017, 09:08 AM Thread Starter
Hi TexasZ,
Thanks for that. It was a case of using what I had laying around. If I had different materials, I might have done it a little differently. The larger rectangular tubing is a bit of overkill. Flat bar would have been fine, and I would have preferred it, if I had any.
The only thing I am not sure of right now is where exactly the balance point is on the bike. I would like to get it as close as possible.
post #6 of 12 (permalink) Old 01-04-2017, 11:07 AM
Bu$aboy79's Avatar
Year/Make/Model: 2004 VN2000A
Displacement/CC's: 2053
Color: Purple... Soon to be Black... Maybe...
Nicely done West Coast!
Would love to see it under the bike when you have some time.
"Never ride faster than your guardian angel can fly... but that little f*ker is pretty damn quick!!"
Bu$aboy79 is offline
post #7 of 12 (permalink) Old 01-04-2017, 08:46 PM Thread Starter
I got the bike up on it tonight.
It is rock solid.
Sure, If I was making a second one, I might change a few things but this will work great. I used what I had on hand.
Now I just have to get a bottle of gas to weld it properly at the weekend. I am completely out. It is always something.
ID:	180530   Click image for larger version
ID:	180538   Click image for larger version
post #8 of 12 (permalink) Old 01-05-2017, 11:25 AM
Year/Make/Model: 2011 Vulcan 900 Custom
Displacement/CC's: 903
I just used some scrap hardwood. You can see my post in the General section "Make that cheap jack/lift fit"
WB
southnam likes this.
Wild Bill is online now
post #9 of 12 (permalink) Old 01-05-2017, 03:59 PM
alwhite00's Avatar
Color: red
Looks great. Nice job.
post #10 of 12 (permalink) Old 01-08-2017, 03:39 PM
WB
You have a link. Maybe I'm blind but could not find it. I need an adapter for my lift.
Sent from my BlackBerry Dtek50
jstutz101 likes this.
southnam is offline
