Repeatedly Breaking Spark Plugs - Why? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 15 (permalink) Old 01-02-2017, 03:34 PM Thread Starter
kileg911's Avatar
Year/Make/Model: 2009 Kawasaki Vulcan 900 & 2014 Kawasaki Ninja 300 ABS
Color: Orange (Vulcan) & Black (Ninja 300)
You may have seen my recent thread regarding a bad fuel pump in my 2009 Vulcan 900 Custom. I got the fuel pump replaced, and the bike was running well. I just rode it in city traffic for about 25-30 miles two days ago, and had zero problems.
When I first bought the bike, I replaced the spark plugs in both cylinders. During my troubleshooting of the fuel pump however, I undid the replacement and put the (presumably) original plugs back in. Those are the plugs that were in the bike when it was most recently ridden, with no problems.
Today I decided that since the plugs still needed to be replaced, I would go ahead and do that. I got the front cylinder (not sure if it's #1 or #2) just fine, but when I did the rear cylinder the spark plug broke. What I mean specifically is that the threaded part of the plug broke off of the rest of the plug, so that the wrench was just spinning the top part of the plug in the hole, but the threaded part (including the tip of the plug) was no longer connected.
After some swearing and a lot of struggling, I managed to get the threaded part out of the hole (with the tip of the plug intact). I took a tiny stick magnet down into the hole to get any tiny metal bits that might have come off when it broke.
I didn't use an extreme amount of force, but figured maybe I overdid it or maybe it was a faulty plug, so I went back to the store and got another. They were out of the exact plugs I'd bought the first time, so I bought another brand that is identical spec. So I know it wasn't just a bad batch of plugs from the same shipment or something.
I got back home, and went to install the new plug. This time I didn't use a wrench, and just finger tightened it (using a spark plug socket and an extension, but no ratchet). As soon as I felt resistance, I got my torque wrench out and set it to 13 ft-lbs (per the service manual). I started tightening the plug, but didn't even get to 13 ft-lbs before I felt it start spinning in place again (just like before). Sure enough I pull out the brand new plug and the exact same thing has happened to it. This time I know I didn't use excessive force. I've replaced spark plugs before in other vehicles so I have at least a little experience and know not to use too much force or you run the risk of stripping the threads in the block.
I'm at a loss. Does anyone know what might cause this to happen twice in a row? Could it be something about the threads? If they were stripped, I would expect the plug to stay in one piece but spin loosely (or be impossible to tighten down). However since two totally different plugs both broke in the same fashion, that points to either the bike, or me.
Any ideas?
EDIT: Okay, I was able to resolve this. The problem was between the seat and the handlebars (user error!)... In the service manual under the spark plug replacement procedures it specifically states, "The insulator of the spark plug may break if the wrench is inclined during tightening." My ratchet extension is just long enough to put the ratchet right next to the frame, which makes it impossible to keep straight when the ratchet (or torque wrench) is attached. Using a longer extension I was able to get a plug in there night and tight, without breaking.
2009 Kawasaki Vulcan 900 Custom
kileg911 is offline
post #2 of 15 (permalink) Old 01-02-2017, 05:41 PM
Bandit's Avatar
Year/Make/Model: 2016 VN 900 Custom
Displacement/CC's: 900
Color: Pearl Crystal White/Metallic Carbon Gray
Glad to hear the problem has been resolved.Time to ride it and enjoy it.
2016 VN900 Custom
Cobra FI2000R Fuel Controller
Kuryakyn Voltmeter
Kawasaki Mini Tachometer
K&N Air Filter
Kuryakyn ISO Grips With Dual Throttle Bosses
Saddlebags Installed Using EasyBrackets
Cobra Freeway Bars
DesertDawg Freeway Bar Chaps
Mustang Wide Vintage Touring Seat With Drivers Backrest
Memphis Shades Batwing Fairing With Lowers
Genmar X12 2" Risers
2014 Ninja 300 SE Pearl StarDust White With ABS
Two Brothers Tarmac Carbon Slip On
TST Integrated Tail/Signal Lights
Bandit is online now
post #3 of 15 (permalink) Old 01-02-2017, 05:56 PM
Rider 50's Avatar
Glad you found your issue.
None of us has had that happen ever. lol
2007 VN 900LT
Ebony Black & Galaxy Silver
Highway bars w/pegs
Saddleman studded seat
Cobra 2 into 1 HP Pro w/peashooter tip
Luggage rack
Home brewed aux. brake light
Home brewed Leather Lowers
Highway bar Chaps
Cobra FI2000 Tri-pot
Redneck air box/K&N filter
Headlight modulator
Other stuff
Rider 50 is offline
post #4 of 15 (permalink) Old 01-02-2017, 08:17 PM
Year/Make/Model: 2011 Vulcan 900 Custom
Displacement/CC's: 903
Wait!!! The torque for spark plugs is 13 inch pounds NOT FOOT pounds (just over 1 foot pound).
13 foot pounds is likely why you broke the plug, hopefully you didn't damage the aluminum cylinder head. You need to divide inch pounds by 12 to get foot pounds. Don't need a lot of force to seat spark plugs.
WB
Wild Bill is offline
post #5 of 15 (permalink) Old 01-02-2017, 08:26 PM Thread Starter
kileg911's Avatar
Are you sure? The service manual specifies 13 ft-lb, not in-lb. It also provides figures in N-m (18 N-m is the spec), which converts to just over 13 ft-lb.
Regardless, I got the plug in without it breaking. The engine runs well and seems to be fine, though I'll need to take it for a longer ride to know for sure.
Sent from my LG-H811 using Tapatalk
kileg911 is offline
post #6 of 15 (permalink) Old 01-03-2017, 01:02 AM
Interesting I have two Kawi service manuals, one for LT model says 13 inch pounds, the 900 custom manual indicates 13 foot pounds. The engine is the same so I assume one of them has a typo. Looking at Victory manual it say 10-14 foot pounds so I think my LT manual with inch pounds is wrong.
post #7 of 15 (permalink) Old 01-03-2017, 06:21 AM Thread Starter
kileg911's Avatar
Strange. 13 ft-lb isn't much force, but 13 in-lb sounds like it would be a little loose. It's certainly possible, there are so many figures in those manuals. Looking around online it seems like most vehicles call for around 15 ft-lb of torque for spark plugs, so I'm guessing this is fairly standard.
In the past when I've done spark plugs I didn't have a torque wrench, but I was told to just make them snug, but not to overdo it. Basically just finger tighten them as far as I could, then give it one more moderate pull with the wrench and call it a day. That's why I was so frustrated with the plugs breaking like they were, since I really wasn't using a lot of force. But I guess I was at just the right angle to cause a problem.
kileg911 is offline
post #8 of 15 (permalink) Old 01-03-2017, 06:37 AM
Just for another data point, the OM for my '12 Classic says 13ft-lb on pg 103.
RickD is offline
post #9 of 15 (permalink) Old 01-03-2017, 10:57 AM
Sonny's Avatar
Year/Make/Model: '09 V900 Classic
Displacement/CC's: dead stock
Color: Plasma blue
Originally Posted by kileg911 View Post
EDIT: Okay, I was able to resolve this. In the service manual under the spark plug replacement procedures it specifically states, "The insulator of the spark plug may break if the wrench is inclined during tightening."
This SM language only warns about breaking the ceramic insulator though, not breaking the hex socket block from the threaded body. I don't know why you had that at all, much less twice.
I've changed a jillion plugs without a torque wrench, hand torquing them "just snug", which prob. translates to well under 10 ft-lbs.. I've never found one loosened up when checking or changing them.
Sonny is offline
post #10 of 15 (permalink) Old 01-03-2017, 11:08 AM Thread Starter
kileg911's Avatar
Yeah, I thought it was referring to another part of the plug. The part that broke on both plugs is metal. It basically snapped off right where the hex socket meets the threaded body, both in the exact same place. I figure it has to be the slight angle, though I don't know for sure.
I got the new plug into the front cylinder and torqued it to spec with no problems whatsoever, but I don't have the frame clearance issue on that side that I do with the rear.
I most likely won't get a chance to ride again until this weekend. When I do I'm planning to ride normally until it is warmed up, then gradually take it up through various amounts of throttle in a few different gears. Basically I want to make sure it's running right, and that the plug doesn't come out or anything under hard acceleration. I'm pretty positive that I didn't do any damage to the threads in the block, but I figure this will be a good test. Anything else I should check for?
kileg911 is offline
