Who has or has not had problems with their 900? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 51 (permalink) Old 07-28-2016, 06:37 PM Thread Starter
Bandit's Avatar
Year/Make/Model: 2016 VN 900 Custom
Displacement/CC's: 900
Color: Pearl Crystal White/Metallic Carbon Gray
I have owned four of these bikes now and was wondering what other owners who have actually accumulated some miles have or have not seen for problems with these bikes.I have a tendency to switch bikes often so have never really put a lot of miles on any of the four.I did have a 2009 that dripped some coolant at about 3000 miles which I resolved by tightening some hose clamps under the gas tank.Also had small amounts of oil form (same bike) on the wiring harness that runs to the regulator.Never did resolve that problem.I never had any of the frequently talked of belt noise and never experienced stator failure but I never put more than 4500 miles on any of the four bikes.Please state year,mileage,and whether modifications may have caused the problem when responding.
2016 VN900 Custom
Cobra FI2000R Fuel Controller
Kuryakyn Voltmeter
Kawasaki Mini Tachometer
K&N Air Filter
Kuryakyn ISO Grips With Dual Throttle Bosses
Saddlebags Installed Using EasyBrackets
Cobra Freeway Bars
DesertDawg Freeway Bar Chaps
Mustang Wide Vintage Touring Seat With Drivers Backrest
Memphis Shades Batwing Fairing With Lowers
Genmar X12 2" Risers
2014 Ninja 300 SE Pearl StarDust White With ABS
Two Brothers Tarmac Carbon Slip On
TST Integrated Tail/Signal Lights
Bandit is online now
post #2 of 51 (permalink) Old 07-28-2016, 06:49 PM
revrider's Avatar
Year/Make/Model: 2010 NOMAD
Color: Black/titanium
2006 900 classic,set of tires,2 batteries and 18k miles,,,NOT ONE PROBLEM,Ran frkn super,miss that bike
revrider is offline
post #3 of 51 (permalink) Old 07-28-2016, 07:17 PM Thread Starter
Bandit's Avatar
Thank you for the reply.I have went to both bigger and smaller bikes from the 900 and back to the 900.Guess I missed mine too.Hoping to keep this one for awhile since I purchased it new which, I normally do not do because of depreciation.
2016 VN900 Custom
Kuryakyn Voltmeter
K&N Air Filter
Cobra Freeway Bars
post #4 of 51 (permalink) Old 07-28-2016, 07:50 PM
Almost 18k on my 2010 custom. Only tires, oil changes and batteries.
Sent from my SM-G930R4 using Tapatalk
jimmy74 is offline
post #5 of 51 (permalink) Old 07-28-2016, 09:22 PM
Hot Cruiser's Avatar
About 12,000 miles on my '07 900 Classic LT - replaced stator and three batteries - only problems. But I ride less now with my increasing age!
Jesus is Lord
Hot Cruiser is offline
post #6 of 51 (permalink) Old 07-29-2016, 06:16 PM Thread Starter
Bandit's Avatar
Thank you for the replies.Keep em comin...
2016 VN900 Custom
Kuryakyn Voltmeter
K&N Air Filter
Cobra Freeway Bars
post #7 of 51 (permalink) Old 07-29-2016, 09:08 PM
white08gt's Avatar
over 21k miles no problems on my 2008 Custom but I only put the last 7k miles on it. PO reported no problems.
white08gt is offline
post #8 of 51 (permalink) Old 07-31-2016, 08:59 AM
Year/Make/Model: 2011 Vulcan 900 Custom
Displacement/CC's: 903
2011 custom (new old stock Purchased Jan 2014). Drive pulley nut came lose around 12k miles?? Started to make a noise when coasting with throttle off. This resulted in some wear to the drive pulley and output spline shaft. After extensive research i have concluded this is not a frequent problem but not all that rare either.
I believe root of the problem is that Kawasaki does not use anti fretting compound on assembly (Seafair recommends anti fretting compound. Proper repair requires engine removal cases split and pulley and output shaft replacement $3000 repair.
I recommend owners check the drive pulley for tightness every 5,000 miles. This requires removing the drive belt from the drive pulley. There should be ZERO slop between the drive pulley and output shaft.
Assuming everything is tight, IN MY OPINION the pulley should be removed anti fretting compound applied a new retaining washer and locktite applied to the locking nut threads, also run the belt with 7-8mm play more in line with other makes for belt drive tension.
If there is any play/slop in the drive pulley it must be addressed. Simply tightening the pulley nut without addressing the slop is NOT a repair as this will be very temporary fix.
I have a temporary repair using locktite 660, a metal paste hardening filler used for filling slop voids in spline shafts and keyways. Not sure how long this will last around 1500 miles on the repair so far will keep my fingers crossed.
WB
Wild Bill is offline
post #9 of 51 (permalink) Old 07-31-2016, 11:21 AM Thread Starter
Bandit's Avatar
WB
I remember the post on that problem.I hope the fix holds up for you.Thank you for replying to this thread.
2016 VN900 Custom
Kuryakyn Voltmeter
K&N Air Filter
Cobra Freeway Bars
post #10 of 51 (permalink) Old 07-31-2016, 07:55 PM
keller123's Avatar
Year/Make/Model: 2008 Vulcan Classic LT 900
Color: Blue/Silver
I bought a 900 with 2007 with like 18000 miles on it, drove it for another 15k and sold it, it was running perfect when I sold, I think the stator had been replaced before I got it, didn't really even read up on the need to adjust the valves, before I sold it, but kind of glad I did since I'm not sure if anybody adjusted the valves at 15,000 like they're supposed to be and I know that I did not adjust them. Just bought a 2008 Vulcan switching back out of a Goldwing, because I love this bike so much, for a number of reasons over the Goldwing, less turbulence, smoother ride, tons less Heat ,15 more miles to the gallon!! Anyway I adjusted the valves at 18000 they were a little off but not much. I would think as long as you do your valve adjustments, and normal other stuff, radiator fluid on time, oil, brake fluid , you're going to have little worries! I think I'll always keep one of these in my garage even if I do go back to some sort of touring, it will not be an old Goldwing though! The only thing I miss about the Goldwing was the seat! 5 to6 our rides were nothing, my butt could only take about 40 minutes on the stock Vulcan, just did the mean City Cycles upgrade, seems to add about another 30 minutes before butt burn , wish I could afford the day-long Russell!
keller123 is offline
