additional rear lighting - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 09-10-2010, 01:20 PM Thread Starter
Stompers's Avatar
anyone added rear lighting to their classic. If so, what did you do and how much $$. Looking for idea's.
2009 Classic 900 Candy Red
OEM W/Shield (23")
OEM Backrest
Mutazu Luggage Rack
Iron Rider rear luggage bag
Saddleman Rigid mount bags
Cobra passenger boards
Jardine highway bar
Kury Highway pegs
Kury lisc plate mount
Cobra Tachometer
Showchrome handlebar temp gauge
Showchrome rear master cylinder cover
Ram-mount GPS (Garmin)
Kury ISO grips with throttle boss
Kury Air Cleaner cover (Scoop)
Mustang Tank Bib
Cobra Lightbar
Stage II Exhaust Mod (4 holes)
Mustang Seat
Stompers is offline
post #2 of 10 (permalink) Old 09-10-2010, 02:45 PM
rpeek2's Avatar
I kinda did. I installed the Kisan SM-3 which turns the rear turners into running lights as well. Changed to red lens making 3 taillights and 3 brakelights. I think I got it for $80 used on Ebay.
MY BEAUTY ** 2008 900 CLASSIC LT
rpeek2 is offline
post #3 of 10 (permalink) Old 09-10-2010, 10:20 PM
Bluecruiser's Avatar
I also used the Kisan SM-3. Gives more visibility, flashing brake lights, and automatic turn signal cancellation. You also can turn on four way flashers or parade mode.
John
2007 900 Custom
Plasma Blue
Oxford, MI
VROC 25948
Bluecruiser is offline
post #4 of 10 (permalink) Old 09-10-2010, 11:19 PM
Kisan SM-3
I'm very interested in adding these, can you detail the installation of them? I like the self cancelling part, I take it that they are set for a certain time and they they shut themselves off? Also price and vendor please?
2009 Black Classic
Mustang Seat w/Backrest
Cobra Standard Backrest with Luggage Rack
Smoke Slipstreamer Windshield
Lindby Multibar Engine Guards
Homemade Lowers
Wally World Running Lights
Stebel Air Horn
Vista Cruise Control
Scootworks Front OD Pulley
Stage 2 Debaffle Stock Pipes
170/80/15 Pirelli Rear Tire
Kury Run/Turn/Brake module
gmer140 is offline
post #5 of 10 (permalink) Old 09-10-2010, 11:34 PM
VicFlo's Avatar
Iplan on adding some extra lights I wanna line the bottom of my fender with some LEDs. If I had hard bags I'd do those as well.
VicFlo is offline
post #6 of 10 (permalink) Old 09-11-2010, 12:56 AM
LiveFreeAndRide's Avatar
I bought the Contours LED License Plate Holder. It's a chrome frame with red light on the top and amber on each side. The amber lamps connect to the turn signal circuit and the red becomes a second tail light. Everything is included for an easy installation.
LiveFreeAndRide is offline
post #7 of 10 (permalink) Old 09-11-2010, 09:56 AM
Here is a great video to watch:
http://community.cruisercustomizing....9&utm_content=
For the Kisan you can find your bike model here:
https://www.kisantech.com/application.php
SignalMinder:
https://www.kisantech.com/index.php?cat_id=4
Installation is not that but you have to track down each rear turn signal and brake wire to tap into them. Mostly plug and play. You have the option of 10, 20, or 30 second time out for the turn signal cancellation.
I also run the Kisan headlight modulator which is plug and play.
https://www.kisantech.com/index.php?cat_id=2
John
2007 900 Custom
Plasma Blue
Oxford, MI
VROC 25948
post #8 of 10 (permalink) Old 09-11-2010, 07:13 PM
rpeek2's Avatar
In addition to Bluecruiser's info:
The unit comes with pretty decent instructions which I think you can access at the website before buying. Read through it to see how detailed you think it is. It replaces the OEM flasher under the seat. You have to splice 3 wires with the provided scotchlocks if you use all of the functions. Black to Green--White to White--Red to Blue. Most problem I had was with the springs you have to put in the turn signal switch. Use the foam ones and you'll probably have to trial and error on the length of them. Once thats figured, damn skippy you are good to go.
Like I said got mine cheaper on Ebay. Price is about the same everywhere else.
rpeek2 is offline
post #9 of 10 (permalink) Old 09-13-2010, 12:46 PM
pkmonson's Avatar
I have a 2009 Classic LT. The Kisan website says that you may have to go with the SM4. Has anyone out there installed this on an 09 and if so which model did you use?
2009 CLASSIC LT, RED TITANIUM
WESTERN MASS
MG Cycles engine Guard
Cobra Light bar w/Visors
Demon Cycles Tachometer
Shark 100w stereo
Fully debaffled
Scootworks Front pulley
Luggage rack
Kurayakyn flame grips
Stebel Air Horn
Mark
pkmonson is offline
post #10 of 10 (permalink) Old 09-13-2010, 02:46 PM
debbiew's Avatar
I used to have the Kuryakn Triple Whammy but was told that the converted signal lights to brake lights were hard to see when signaling. I am getting another 900 tomorrow (totaled my last one in August) and these were recommended to me. Specifically the U32 kit. You would need the bracket to install (I think). http://www.hyperlites.com/stdsf.html
'09 Vulcan 900 Classic
Black
VROC # 28064
debbiew is offline
