What do you think caused this?? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 20 (permalink) Old 10-30-2012, 11:40 AM Thread Starter
xringer's Avatar
Fellow riders:
I put a set of Pirelli's on 3000 miles ago on my Vulcan 500. I took the front tire off yesterday to put a new tube in cuz it's loosing 5 lbs. a week. (tube is 7 years old.) I noticed this on the tire, and is/on several places on the front tire as well on the rear tire. What do you think caused this? When I have the tube replaced I'm going to ask if it's safe to run these tires.
Thanks, Dan
xringer is offline
post #2 of 20 (permalink) Old 10-30-2012, 11:54 AM
Joelg's Avatar
Battery acid?? It doesn't look like heat, or anything normal. I'd think it was chemical one way or another.
Joel
2007 Vulcan 1500 Classic
Joelg is offline
post #3 of 20 (permalink) Old 10-30-2012, 12:24 PM Thread Starter
xringer's Avatar
Joel
Thanks Joel.............but I don't see any leaking around the battery, or the tube that leads down. I put some of that tire foam about a month ago and did'nt notice it then. I can't imanage tire foam would do that. Crazy thing is it's on both tires, & both sides.
xringer is offline
post #4 of 20 (permalink) Old 10-30-2012, 12:36 PM
Ok, I know you are going to want to put me in a rubber room. But what about a critter. Mouse or Chipmonk, something like that. We had a travel trailer a few years ago and one weekend we get to the park and I turn on the propane. Start hearing gas escaping. Follow the hose to an area where some little critter had chewed a hole. Did not cover a big area, but managed to nip the center. The picture looks like mostly "thick scratches" in a generally up and down direction. When I replaced the propane hose the guy told me it happens enough that he was not suprised. Seems like there must be some "smell" that attracts the critter and they chew away. Who knows somebody may have worked on your bike right after lunch of something.
Anyway, don't know but a close look may be able to determine melting rubber (chemical) versus removed rubber (mechanical or dental). Good luck
2009, 900 Vulcan LT Classic
Modifications
Modulating Headlight
Flashing Tail Light
Wolo Bad Boy Air Horn
Kick-back Risers
Custom GPS Holder
Papa Smrph is offline
post #5 of 20 (permalink) Old 10-30-2012, 12:36 PM
Administrator
MN-Rider's Avatar
Displacement/CC's: 1800
Color: Pearl White
You need a gremlin bell real bad!
Jeff, Twin Cities, MN
Please add your bike info to your profile (User CP>top right>edit your details. If mobile,exit enhanced mobile view)
MN-Rider is offline
post #6 of 20 (permalink) Old 10-30-2012, 01:24 PM
DESERT ANGEL's Avatar
I would think the nipples would be gone by 3000 miles it still looks new
my guess looks like a hot soldering iron
or if tacky bad production rubber not cured right
I think tires are not afected by most chemicals
good luck
DESERT ANGEL is offline
post #7 of 20 (permalink) Old 10-30-2012, 01:32 PM Thread Starter
xringer's Avatar
Papa....I wish it were a critter, like a mouse or Chipmonk..lol....but I don't see and "teeth marks" or claw marks...no mouse or Chipmonk dropings either.
xringer is offline
post #8 of 20 (permalink) Old 10-30-2012, 01:38 PM Thread Starter
xringer's Avatar
good luck
Desert........the nipples are on the side of the tires where I don't ride much..lol....but your right it does look like a soldering iron but on both sides of both tires? It is also not "tacky".......this one's really got me baffled!
xringer is offline
post #9 of 20 (permalink) Old 10-30-2012, 09:20 PM
rick's Avatar
Hate to say it, but now that its been mentioned, does look more like burning by something HOT like a soildering iron. Any resent enimies, or an ex maybe? May want to do a complete inspection before you ride for awhile. Hate to think of this possibility!
rick is offline
post #10 of 20 (permalink) Old 10-31-2012, 01:43 AM
Super Moderator
Color: Orange SE
You said you took the tire off, and the 500 has exhaust on both sides. Any possibility you bumped the tire against hot exhaust or scraped it on something pulling it off?
Romans5.8 is offline
