Dunlop Tire wear - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 19 (permalink) Old 07-31-2012, 03:20 PM Thread Starter
bosco's Avatar
Unhappy Dunlop Tire wear
Has anyone seen this before? Seems unusual to have the left side of the front tire wear so much more than the center or right side. I was following the service manual and kept the tire inflated to 28psi. I have now been told this should have been closer to 36psi. If 28psi is under inflated would it cause this type of wear? This is the front tire for a Vulcan 900 classic with 5900 miles (original tire).
Would like to hear everyone's thoughts? Is there a way to check alignment?
Name:	Front tire 1.jpg
ID:	12487   Click image for larger version
Name:	Front tire 2.jpg
2010 900 Classic
bosco is offline
post #2 of 19 (permalink) Old 07-31-2012, 03:42 PM
whoaru99's Avatar
It is not particularly unusual to see the left side of the tire worn more.
There are two arguments why:
1. Left side of the tire gets more miles put on it. Left turns (at least from the RH side of the road) are longer than right turns, therefore left side accumulates more miles.
2. Crown of the road.
I'm more in tune with #1, but in the end it doesn't really matter. What matters is that what you're seeing isn't inherently indicative of a tire/tire maintenance problem.
whoaru99 is offline
post #3 of 19 (permalink) Old 07-31-2012, 03:44 PM
pacomutt's Avatar
Probably because you're right-handed.
Otherwise, could your alignment be off because you tried to track your belt?
Ron in Cincinnati
.........Bob Seger
pacomutt is offline
post #4 of 19 (permalink) Old 07-31-2012, 03:48 PM
Daboo311's Avatar
I'm just now hitting 6000 on my custom. The wear on mine in more in the middle. Umm! You wouldn't happen to be sitting side-saddle would you?
Daboo311 is offline
post #5 of 19 (permalink) Old 07-31-2012, 03:49 PM
whoaru99's Avatar
I think it's way too far down the side to be an alignment issue. To wear that far down the side you'd have to be leaned over...like in a LH turn.
whoaru99 is offline
post #6 of 19 (permalink) Old 07-31-2012, 03:55 PM
Daboo311's Avatar
Also, makes me wonder if this bike had a previous owner and it was laid down...
Daboo311 is offline
post #7 of 19 (permalink) Old 07-31-2012, 04:13 PM
I have Dunlop D404's on my bike. I have more than 5,000 on the tires and they are wearing pretty evenly. Also I run 40lbs in my tires, instead of 36 or 28 as, recommeneded by the tire manufacturer. Tire pressure in the book gives a smooth ride, but 40lbs gives better tire life and gas mileage.
06 1500 Classic FI (Anniversary Edition)
Reward the truth, punish the liars...Ted Nugent
Dean is offline
post #8 of 19 (permalink) Old 07-31-2012, 04:14 PM
In fact, I have close to 10,000 on my tires and they are about 18 months old.
Dean is offline
post #9 of 19 (permalink) Old 07-31-2012, 04:51 PM Thread Starter
bosco's Avatar
Thanks for all the replys so far. Getting a new tire put on this afternoon.
Both make excellent sense. I have noticed that are roads here in So Cal. can have a pretty good crown on them, I have even noticed myself leaning that way on some of them.
This is the front tire, would rear wheel aligment impact the front? the rear tire looks really good right now.
LOL........
I'm the original owner, so no.
2010 900 Classic
bosco is offline
post #10 of 19 (permalink) Old 08-03-2012, 07:35 AM
whoaru99's Avatar
I think it could/would, but any time my rear wheel alignment has been off any appreciable amount I've felt it in the bars, needing to compensate more one way or the other/work harder to keep the bike going straight.
whoaru99 is offline
