engine knocking - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 06-17-2013, 11:34 PM Thread Starter
marley's Avatar
engine knocking
I have an 04 1500 vulcan and since reaching 20,000miles there is a knocking coming from the engine. It's particularly noticeable at idle but I can hear it at speed too. Should I be worried?
marley is offline
post #2 of 10 (permalink) Old 06-18-2013, 10:58 AM
not sure about the 1500, but i know the 800's have some rubber isolators in the bottom end of the engine that harden after a few years and make a knocking sound. If the 1500 has the same thing that could be what it is, my 800 has done it since i bought it and other than the noise it hasnt caused any issues.
1995 Vulcan 800
"The reason I don't ride a Harley isn't that i cant afford the motorcycle...it's that I cant afford the damn clothes" - Me to a guy that said "why didn't you buy a Harley instead of that rice burner, can't you afford a real motorcycle"
Adamshirley is offline
post #3 of 10 (permalink) Old 06-18-2013, 11:10 AM
PatC's Avatar
My '04 1500 has made noises since I've had it and have gotten louder as it broke in. There are days I swear it's going to come apart, but it seems to be quite normal for these bikes. Knocking, rattling, clicking- it would be hard to tell if anything was really wrong! I have 41.5k on mine and it's still running strong.
Here's a good resource. Scroll down to number 5.
http://www.gadgetjq.com/newbie.htm
04 1500 Classic
Mustang Seat
Sissy bar, luggage rack,
light bar, 2" risers,
Isogrips, Fatbar crashbars,
offset hiway pegs, tank bib,
passenger floorboards,
new brake pedal, throttle lock,
Cobra Lowboy Shotgun pipes,
Baron's Big Air relocated right side,
tombstone tail light,forkbag,
detachable hard leather bags,
alarm, power port, clock,
and a cool cupholder
PatC is offline
post #4 of 10 (permalink) Old 06-18-2013, 12:57 PM
It's the nature of a V-Twin. Every one that I've owned (7 of them) have had a knock and other crazy engine sounds. My current 2011 Voyager has just shy of 50,000 miles on it. It runs great uses no oil and knocks all the time, sometimes worse than other. I don't even hear it anymore, or at least just ignore it. The Vulcans are still quiet compared to a Victory or a Harley.
Dr.G is offline
post #5 of 10 (permalink) Old 06-18-2013, 04:14 PM
07vn2000's Avatar
Check the timing chain seems to be a common problem
https://www.youtube.com/watch?v=4DWz_p-2BSA
07vn2000 is offline
post #6 of 10 (permalink) Old 06-18-2013, 09:12 PM Thread Starter
marley's Avatar
Well,that helps but when I got on it today it would only stay at a high rev. When I downshift it doesn't slow like the throttle is stuck.
marley is offline
post #7 of 10 (permalink) Old 06-19-2013, 10:35 AM
Well that's a different kind of problem. Check to make sure the throttle cables are adjusted correctly. Sometimes when people put on new grips they don't get the cables back to the proper adjustment. Ray has a good thread on the proper adjustment technique here on this forum. Also may be time to clean the throttle bodies, there is also a thread on this topic if you do a search. Both are pretty easy to do, hope this helps.
Dr.G is offline
post #8 of 10 (permalink) Old 06-19-2013, 10:40 AM
Another thing, I just noticed your bike is a 04. It has a fast idle adjustment on the left side used for cold starts. Make sure that's not in the out position.
Dr.G is offline
post #9 of 10 (permalink) Old 06-19-2013, 09:49 PM
PatC's Avatar
If it's an '04 classic, it's probably carbed.
04 1500 Classic
Mustang Seat
PatC is offline
post #10 of 10 (permalink) Old 06-05-2015, 10:48 AM
I also have a '97 Honda Shadow VT1100 ith 73000 mi. and it is completely quiet at all speeds. 2015 with 1000 milesThe kawa 900 can be annoying though.
chuckwgn is offline
