won`t start under 40 deg - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 11-25-2012, 09:45 AM Thread Starter
got an 02 nomad with V&H, Dynatek fi controler,runs perfect ecept won`t start when it real cod in the am. help please
just ride
harvey
uride2 is offline
post #2 of 10 (permalink) Old 11-25-2012, 11:08 AM
Maybe put hotter plug in it. Next hotter plug.
Cagecam is offline
post #3 of 10 (permalink) Old 11-25-2012, 01:57 PM
Sorry, hotter spark plug will not help.
Do you use the fast idle knob down by the ignition switch on cold start?
Post back.
sfair is offline
post #4 of 10 (permalink) Old 11-25-2012, 02:22 PM Thread Starter
Originally Posted by sfair View Post
Sorry, hotter spark p,lug will not help.
Post back.
yes,the bike starts after the out door temp heats up
uride2 is offline
post #5 of 10 (permalink) Old 11-26-2012, 10:36 AM
On the fast idle knob, it pulls easily for the first bit...taking up slack, then it gets a lot tougher...this is where it starts to do something. Are you pulling it through the tougher region?
Post back.
sfair is offline
post #6 of 10 (permalink) Old 11-26-2012, 05:08 PM
Angel of Death's Avatar
On mine, the fast idle knob had little to no effect (even when operated properly as described by sfair) until I also did the throttle body cleaning. Noticed especially when colder.
Sent from my iPhone using Motorcycle.com App
-- AoD
_______________________
'01 1500 Classic FI
28k miles
V&H Longshots
Thunder air kit
K&N air filter
Grasshopper backrest
Lindby Linbar highway bar
Kuryakyn Iso Dually pegs
Jardine grips
Baron's Mini-Tach black
Angel of Death is offline
post #7 of 10 (permalink) Old 11-27-2012, 07:19 AM Thread Starter
the temp in centeral fkorida has stayed above 40 for the last few days.pull the choke out hard and i think i had it all the way out,but i`ll try it next time it get cold.jjust ride
uride2 is offline
post #8 of 10 (permalink) Old 11-27-2012, 07:18 PM
FWIW, don't have to wait till its cold to see if fast idle lever does anything. It still should bump up the idle noticeably. If not then you could check into TB cleaning now and maybe be ready for next time is cold... or start diagnosing why else the lever doesn't work.
-- AoD
'01 1500 Classic FI
28k miles
V&H Longshots
Thunder air kit
K&N air filter
Jardine grips
post #9 of 10 (permalink) Old 11-28-2012, 06:47 PM Thread Starter
DAAAH,try it the rpm go up, man what a great day rode ofer the skyway bridge,and over to st Pete Pier
uride2 is offline
post #10 of 10 (permalink) Old 11-28-2012, 07:18 PM
Are you saying that pulling the knob into the tough zone worked for you? (Cannot believe I just said that!)
Post back.
sfair is offline
