Exhaust Pipes Seal Question - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 11-12-2012, 08:56 AM Thread Starter
Comanche's Avatar
On my HD's in the past I have used PermaTex High-Temp Sealant around the area where the exhaust pipes fit into the head to seal them.
Since the newly acquired VN800 Classic I now own has aluminum ring gasket type seals that fit around the mouth of the pipe and fit into the recessed area on each head does anyone think it a good idea to use a little PermaTex High-Temp there to help seal the rings and pipes better?
Comanche is offline
post #2 of 7 (permalink) Old 11-12-2012, 05:40 PM
permatex?
I doubt it. Probably best to replace the seals each time the pipe is removed. The gaskets only cost 2or 3 dollars each on mine. If the permatex does work though- let us know.
vulcanfun is offline
post #3 of 7 (permalink) Old 11-12-2012, 05:42 PM
Yammadof's Avatar
I used a little just to seat the gasket seals in the recessed area of the cylinder while mounting the pipes...otherwise you need three hands [further proof evolution is a myth....]
Dave
1996 VN 800 Classic
Memphis Fats
MAC Fat Stakkers
Yammadof is offline
post #4 of 7 (permalink) Old 11-12-2012, 06:19 PM Thread Starter
Comanche's Avatar
Dave
Exactly, Dave. That's how I've done it with my HD's in the past and some HD mechs even say to do that. Just wanted to know about this with Vulcans since it doesn't need much to hold and seal there. The Ultra Black is what I've used in the past just like you said. Will test it out with new gaskets and see what happens with the Vulcan. I'm not slathering it on in excess and just using a little to hold the ring in place and seal where it mounts flush. Not putting it on flush mounting surfaces either just around the ring.
Comanche is offline
post #5 of 7 (permalink) Old 11-12-2012, 06:45 PM
Yammadof's Avatar
Yep...that's what I did to put the Fat Stakkers on - worked a treat....just a little tight to get the 8mm hex wrench in...
Dave
1996 VN 800 Classic
Memphis Fats
MAC Fat Stakkers
Yammadof is offline
post #6 of 7 (permalink) Old 11-13-2012, 08:11 AM
Bear2123's Avatar
I put Cobra Slashcuts on mine, with new gaskets, and didn't need a sealant.
Bear2123 is offline
post #7 of 7 (permalink) Old 11-13-2012, 10:23 AM Thread Starter
Comanche's Avatar
It's not so much a "need" for it but to ensure that it seals extremely well. Again, it's not like caking and slathering it on like a corner prostitute does her makeup during Mardis Gras. Just a very small amount to ensure that the mating surfaces seal completely. I also have Cobra Slashcuts but like I always say to each his own. I just don't like leaks anywhere whether fuel, water, exhaust, oil, brake fluid. It's a habit I picked up from my HD's so you know how that is with a rider's habits. Haha. For sure we all can quickly swear by our own habits and then turn around and swear just as fast at cagers who cut us off and endanger us every time we ride. I once heard an old guy say, I swear I ride faster because of my long hair even though California has helmet laws. Dude was bald everywhere except the sides of his head. Hilarious.
Comanche is offline
