Valve Clearance Question - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 49 (permalink) Old 11-03-2012, 03:46 PM Thread Starter
I pulled the valve covers and moved the piston to TF. I tried to check the valve clearance and couldn't even get the thinnest feeler gauge leaf between the shim and the rocker arm. The bike has almost 15k miles on it. Is that normal?
_____________________________________________
2010 Vulcan 900 Classic LT [Debadged]
Lindby Linbar
Baron Big Air Kit
Cobra Fi2000 PowrPro
Rear Scootworks OD Pulley
Debaffled stock exhaust
Mustang Wide Touring Seat
USMC
Iraqi Freedom Veteran
Infidel is offline
post #2 of 49 (permalink) Old 11-03-2012, 04:35 PM
pacomutt's Avatar
Checking the correct cylinder for that timing mark?
Ron in Cincinnati
.........Bob Seger
pacomutt is offline
post #3 of 49 (permalink) Old 11-03-2012, 06:24 PM Thread Starter
I believe so. I'm checking the front cylinder when TF is aligned. I haven't checked the rear with TR aligned yet...
I even tried to get the thinnest feeler gauge between the rocker arm and the shim on the exhaust side without any luck....I must be doing something wrong....back to the manual....
Lindby Linbar
Baron Big Air Kit
USMC
Infidel is offline
post #4 of 49 (permalink) Old 11-03-2012, 07:42 PM
Do not forget that there are two possible positions for TF...one at TDC on compression stroke and one at TDC on exhaust stroke.
sfair is offline
post #5 of 49 (permalink) Old 11-03-2012, 08:06 PM Thread Starter
I spun it so the TF is aligned with the mark and the cut on the gear is aligned with the top of the cylinder head. Still no love. I just bought a shim kit so I can swap them out. I'm pretty sure I followed the manual correctly...it's just that this is my first time and I don't want to mess anything up. What are the consequences of the valve clearance being off a little?
Lindby Linbar
Baron Big Air Kit
USMC
Infidel is offline
post #6 of 49 (permalink) Old 11-03-2012, 08:13 PM Thread Starter
Also, the kit I bought goes from thickness of 1.20 to 3.50, but the shims I pulled from the bike are 4.?0. I can't read the middle number. Shouldn't they be in the same range as the kit?
Lindby Linbar
Baron Big Air Kit
USMC
Infidel is offline
post #7 of 49 (permalink) Old 11-03-2012, 08:16 PM Thread Starter
Nevermind, that can't be the thickness number, since the shim is thinner than the 3.50. I'll play with the shims until I get the clearance I need.
Lindby Linbar
Baron Big Air Kit
USMC
Infidel is offline
post #8 of 49 (permalink) Old 11-03-2012, 10:09 PM
Just to make sure that you are at the correct TDC, rock crankshaft back and forth about ten degrees (or more) and there should be no valve train movement at all.
sfair is offline
post #9 of 49 (permalink) Old 11-03-2012, 10:10 PM
rick's Avatar
Another method is to watch your cam lobe, the high spot on the cam. When it is facing up, your valve will be open, turn motor till it is completely down, your valve should be completely closed at this point and you can adjust it there.
rick is offline
post #10 of 49 (permalink) Old 11-03-2012, 11:03 PM Thread Starter
Thanks guys. I guess the clearance really was shot. I adjusted the two intake valves on the front, then did the exhaust. Three of the 4 shims needed to be adjusted. Same with the back cylinder.
AND! as a grand finale, I hooked everything back up and tried to start the bike. Apparently, I forgot to reconnect the line with the lock that connects on the left side of the tank.......gotta let the garage air out overnight now....
Damn, computers are so much easier to mess with. HAHA!
Again, thanks for the tips, guys!
Lindby Linbar
Baron Big Air Kit
USMC
Infidel is offline
