3 months back while on the Freeway, my engine just stopped. Pulled over and started pushing to get it off the freeway. Tried starting it and sometimes it would run for a short period, so it off the Freeway. Got a trailer and took it to Simi Valley Kawasaki. Mechanic couldn't really find what was wrong with it as it started running. Took it home, found that my Kuryakyn Pro Series Hypercharger wasn't working and fixed that. Rode it for a month, and then it did the same thing. On freeway, engine would quit, pulled over, but still coasting, popped clutch, and got it running for a short distance, then quits. Anyway, I drove it by side streets and about a mile from home, going to slow and couldn’t pop the clutch to get it started. Called wife and she brought me my mini jumpstarter. Got it started enough to get it the rest of the way home. At home hard to get it running, and when I did, I could get it down the block before I recognized the symptoms, turned around and it would die coming up the driveway. Called mechanic and he suggested the relay box so he loaned me a new box and I switched it out. Didn’t help. Then had issues getting it started as it wouldn’t crank right. Bought a new battery. Put it in, it cranked okay and got it started, seemed to idle okay so turned it off. Put seat back on, started it up, but then it was harder, and then nothing. Took seat off and found that my positive post on the new battery was completely melted. Got another battery from place I got battery from, and trailered the whole thing back to the mechanic. He checked starter, and it was good. He says that it is hard to turn over and maybe something is broken inside and I should sell for parts as it would cost at least $3,000 to fix it. Anyway, rented a U-Haul and went to pick it up. Mechanic showed me that even with the plugs removed, taking a breaker bar to it to turn the motor over, it took a lot of effort to do so, more than it should have been. Have it in the garage now and it is my next planned project. Anybody have any ideas where to start and what to look for?
