VN1500A Classic starter/electrical issues - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 11-29-2012, 01:20 PM Thread Starter
hello.. have a 1995 vulcan classic. with a fully charged battery and CCA amps electrically verified by a local auto store, the bike will turn over but if it doesnt start, i press the starter again and i hear the relay which im guessing is the solenoid not having enough voltage to energize therefore the clicking due to low voltage. is their a problem that anyone has seen with a weak starter or a solenoid problem???
thanks
Sam
sambeaux is offline
post #2 of 5 (permalink) Old 11-29-2012, 02:23 PM
Your best bet is to verify what the auto store has done. There have been times when the test was done incorrectly.
You will need a meter and know how to use it. No meter? We can help you purchase and learn how to use.
Post back.
sfair is offline
post #3 of 5 (permalink) Old 11-29-2012, 03:09 PM
Banned
Check that your starter is good it could be over amping the system because the brushes are bad and is not able to turn the bike over.
DBBromberg is offline
post #4 of 5 (permalink) Old 11-29-2012, 06:35 PM
As an add, Kawasaki starters give little to no trouble, so it is the last item on the list of usual suspects.
sfair is offline
post #5 of 5 (permalink) Old 11-29-2012, 06:54 PM
Banned
Not going to argue with you there....when you have eliminated the impossible, whatever remains, however improbable, must be the truth. Sir Arthur Conan Doyle, (Sherlock Holmes) ...
