2004 nomad 1500 fi - idle solenoid removal - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 11-27-2012, 08:46 AM Thread Starter
i have cobra speedster long pipes, thunder mfg. aftermarket airbox, and a fuel management system. the idle solenoids were removed as per instructions to install the airbox backing plate and airbox. the vaccum line to the reed valves was plugged. now that the weather has cooled my cold start-up has consisted of a very rough idle - it would stall if i did not stay on the throttle. also i have excessive smoke from the pipes (running rich). this all occurs until the motor warms up then the idle smoothes out and i release the throttle. is there a way to remedy this situation, maybe my set-up needs an adjustment. any help would be appreciated.
nomadrider2004 is offline
post #2 of 2 (permalink) Old 11-27-2012, 09:33 AM
That is why the factory installed the idle soleniods in the first place...to cover the exact situation that you are having. They would not have included them if not necessary, the cheapskates that they are.
Sorry.
sfair is offline
