locator pin - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 8 (permalink) Old 11-26-2012, 08:23 AM Thread Starter
locator pin
I redid the top end of my 1988 88se and just found out that I forgot to install one of the 2 locator pins in the top of the head (head to rocker box).Should I take it back apart and put it in,or will it be fine to run?
Sick Boy is offline
post #2 of 8 (permalink) Old 11-26-2012, 09:38 AM
rick's Avatar
If it is just a pin to locate the cover and you have no leaks, you shold be fine. If it locates a stressed, or noving part, I would put it in. Am sure your talking about locating the valve cover though, so should be just fine.
rick is offline
post #3 of 8 (permalink) Old 11-26-2012, 11:21 AM Thread Starter
No,it goes between the head & the rocker box.The locators are hollow and the head studs go through them.There are 2 on the bottom of the head,that fit into the cylinder.Then there are 2 on the top of the head,that fit into the rocker box (that is where I only have one).
Sick Boy is offline
post #4 of 8 (permalink) Old 11-26-2012, 12:14 PM
rick's Avatar
Then I think it would be a good idea to install it. It may be needed to help keep the head from moving around as it heats up and cools. Could shorten head gasket life if not installed.
rick is offline
post #5 of 8 (permalink) Old 11-27-2012, 07:48 PM
cjlam's Avatar
I go by the theory extra parts are not good.. I would install
01 Classic
Full Nomad rear hard bags
cjlam is offline
post #6 of 8 (permalink) Old 11-27-2012, 08:09 PM
Comanche's Avatar
Ya think? Don't you just hate it when that happens?!
Comanche is offline
post #7 of 8 (permalink) Old 11-29-2012, 07:30 AM Thread Starter
Back together with BOTH pins...
Sick Boy is offline
post #8 of 8 (permalink) Old 11-29-2012, 07:35 PM
cjlam's Avatar
Good idea... Btw find anything else
01 Classic
cjlam is offline
