1997 1500 Classic hi beam does not work - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 11-25-2012, 01:13 PM Thread Starter
dcn
The low beam works but not the hi beams which my driving lights work off. I have not tested anything yet. An suggestions on how to proceed.
dcn is offline
post #2 of 5 (permalink) Old 11-25-2012, 01:45 PM
I'm not a mechanic but I would remove the lamp and check the voltage at the connector. If you have 12v with the switch on then your lamp is blown.
Or you could just repalce the lamp because that is probably what it is. The lamp filament on the high beam side is probably burnt into, you have to replace the whole lamp.
2001 Drifter 1500
Pilgrim is offline
post #3 of 5 (permalink) Old 11-30-2012, 08:13 PM
You said your driving lights work off your high beam, do you mean like aux/fog lights spliced into the high beam switch? if that is the case then check/re check the swith and all conections... most likely a lose ground. I would recomend running a seperrate on'off switch for you aux lights.
rusty_is_riding4life is offline
post #4 of 5 (permalink) Old 11-30-2012, 09:58 PM
Murphy's Avatar
Replace the bulb and take it from there
06 VN1500 Classic Anniversary
Murphy is offline
post #5 of 5 (permalink) Old 12-04-2012, 07:06 PM
screwedandtattooed's Avatar
I had this problem when I installed my apes, except in reverse only my high beam was working once I put everything back together. I replaced the bulb and checked voltage and all that jazz. Ended up being a pinched wire in the hand controls so I backed out the screws not enough to be loose but enough to relieve pressure and everything started working again I haven't had any problems since. Hopefully that helps.
'97 vulcan 1500 classic carb
vance and hines straight shots
screwedandtattooed is offline
