Stock air intake VS Caddmann Mod - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 11-24-2012, 07:30 PM Thread Starter
KahWahSahKey's Avatar
I have a 2006 Vulcan 1500 Classic FI. I put on Cobra longshot pipes (with torque cones at the headers) & did the Caddmann mod to the right side only. I also did the air temp sensor/resistor mod. I do NOT have a power commander.
I assume if I go back to the stock intake I should remove the resistor, yes?
Before I do this, what I'm wondering is if I will gain or lose anything by going back to the stock setup for the air intake. Quite frankly, I'm kind of tired of the sound of the bike sucking in air when I hit the throttle.
KahWahSahKey is offline
post #2 of 10 (permalink) Old 11-25-2012, 10:34 PM Thread Starter
Anyone? I'd appreciate it!
post #3 of 10 (permalink) Old 11-26-2012, 11:30 AM
rick's Avatar
If not going to do something to adjust your air/fuel, thinking be better off going back to the stock filter, your most likely running pretty lean now.
rick is offline
post #4 of 10 (permalink) Old 11-26-2012, 11:38 AM
IL Vaquero's Avatar
I would think you are running way to lean and need a fuel manager of some sort to get the power you want. Or go back stock.
Only a motorcycle rider knows why a dog sticks he head out the car window. Enjoy life.
IL Vaquero is offline
post #5 of 10 (permalink) Old 11-26-2012, 01:37 PM Thread Starter
I did the resistor mod to deal with the fuel mixture & based on the appearance of the spark plugs I'm not running lean.
What I want to know is if I go back to stock should I undo the resistor mod?
Since I don't have a power commander it seems I have nothing to lose by going back to stock, right?
Sent from my Samsung Epic 4G, but not while riding!
post #6 of 10 (permalink) Old 11-26-2012, 02:19 PM
rick's Avatar
Try the stock setup. Check your plugs after maybe a 10 mile ride. If it runs good and the plugs look ok, you should be fine with the resister mod. Most all bikes run on the lean side in factory trim as is.
rick is offline
post #7 of 10 (permalink) Old 11-26-2012, 09:02 PM Thread Starter
Thanks!
Btw, anyone wanna buy a K&N filter for the Caddmann mod?
post #8 of 10 (permalink) Old 11-30-2012, 09:59 AM Thread Starter
One last question on this...memory is failing me. I have the dog bowl for the right side, but I don't have a filter anywhere. I know this is going to sound foolish, but I honestly can't remember...is there a filter on the right side too, or only on the left?
Thanks again!
post #9 of 10 (permalink) Old 11-30-2012, 10:02 AM
markstep's Avatar
Send a message via Skype™ to markstep
Only one filter
2003 1500 Meanstreak
Hardchrome pipes
saddle bags
MS hot shot windscreen
Fuel Genies
not sure what else added by p/o
markstep is offline
post #10 of 10 (permalink) Old 11-30-2012, 10:26 AM Thread Starter
Thanks!!!!
