help-bike wont go - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 11-11-2012, 05:06 PM Thread Starter
help-bike wont go
My 98 1500 classic was running fine a few months ago, but recently when I took it out on a nice day for a ride it would not move. When I put it in first gear it gives a little lerch forward like it always did, but when I let the clutch out it acts like its in nutreal and dosent move at all. The clutch lever dosent have the same feeling when I pull it in as it did before. The fluid reservoir is full.
Lonslo is offline
post #2 of 10 (permalink) Old 11-14-2012, 10:57 AM
you might try to bleed to line to the clutch. It might have an air pocket in it. Not sure how it would have got air in it but it is worth a try.
tereich is offline
post #3 of 10 (permalink) Old 11-14-2012, 11:09 AM
SWVA_08V2k's Avatar
It is a 98 model has there been any clutch work done to it in the past? Also any recent oil changes? Was it an abrupt change or has it gradually been getting worse and worse.
Throw out some more info
Mileage?
any resent mods?
SWVA_08V2k is offline
post #4 of 10 (permalink) Old 11-14-2012, 11:25 AM
Remove the top of the clutch master cylinder and peer down to the bottom.
There you will see two small holes. Gently poke a nylon bristle or copper wire into the holes to ensure they are free.
If that works, then a fluid flush and refill will be in order.
sfair is offline
post #5 of 10 (permalink) Old 11-14-2012, 05:28 PM Thread Starter
I put a clutch spring in about 3 years ago. No oil change recently. I have 31,000 miles on the bike. Like I said, it ran good when I put it away, no problem at all. Now all of a sudden it dosen't want to move. I would think that if the clutch isn't being released it would not go into gear and if it did it would surge ahead. It just acts like its in neutral except for the slight jerk when I put it in gear.
Lonslo is offline
post #6 of 10 (permalink) Old 11-14-2012, 06:49 PM
Banned
When my bike has been sitting awhile, I think the clutch plates stick and the bike will lerch forward when I put bike into 1st gear with clutch lever pulled in, after the 1st lerch forward it is ok after that.
Degreaser is offline
post #7 of 10 (permalink) Old 11-14-2012, 07:02 PM
Sounds like the clutch is not releasing, and what can cause that, among other things, is a plugged relief port.
See post #4.
sfair is offline
post #8 of 10 (permalink) Old 11-15-2012, 12:17 AM
pcarrell's Avatar
Good advice so far. Try this....
Start the bike with it in first gear, clutch pulled in and brakes on (might give you a jerk as it starts). If the clutch plates are sticking, a lot of times this will free them.
Had a friend with a similar problem and this cured it.
Philip
BOTM Winner, February 2010, December 2012, August 2014
Third Place BOTY 2012
Third Place BOTY 2014
pcarrell is offline
post #9 of 10 (permalink) Old 11-15-2012, 07:02 AM
SWVA_08V2k's Avatar
I am agreeing with sfair. It sounds like your relief port is clogged not letting the fluid back off the pressure to release the clutch. See if you can clean them out and let us know if that works or not.
post #10 of 10 (permalink) Old 11-16-2012, 06:04 PM Thread Starter
Thank you all that responded to my post. I siphoned out the old fluid from the master cylinder. Cleaned out the hole on the bottom and put in fresh fluid. Started the bike, put it in gear, and what do ya know, problem solved. You guys (and maybe girls) are great. I have another problem that I will post at a future date. Thank you all again.
Lonslo is offline
