Fuel Pump Issues - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
post #11 of 19 (permalink) Old 10-28-2012, 01:21 AM
DESERT ANGEL's Avatar
keep in mind
the pump wll run backwards if wires are swiched
DESERT ANGEL is offline
post #12 of 19 (permalink) Old 10-28-2012, 04:35 AM Thread Starter
This is great, will save me a lot of money and get this up and running quick. Thank you soo much
llplacek is offline
post #13 of 19 (permalink) Old 11-04-2012, 03:18 PM Thread Starter
Well so far got 2 different pumps and not matching up. The one on Ebay thru High Flow, first of all didn't come with all accessories show, main thing being the Rubber Isolator/Holder on the opposite side of the terminals. I'm getting back and forth email but saying can't get that part and saying it will work with the old one, but no match. So I went with option 2 Airtex E2111 thru Advanced Auto. The pump is close match, terminals a little different and length different and this came with Rubber Isolator/Holder but will not fit and hold into my Pump assemble. Now have 2 pumps to return and wasted time? Any ideas?
llplacek is offline
post #14 of 19 (permalink) Old 11-04-2012, 04:00 PM
Bandit101's Avatar
Year/Make/Model: 2015
Displacement/CC's: 103ci
Color: Black
If you buy the correct part to start with you will be money and time ahead. This will work.
http://www.ebay.com/itm/02-Kawasaki-...90351e&vxp=mtr
Bandit101 is offline
post #15 of 19 (permalink) Old 11-04-2012, 04:29 PM Thread Starter
I appreciate that, but i'm not spending $190 on a used pump and be in the same situation. I just want to replace the pump with a new pump, don't need the assemble.
But thank you for the response and the link
llplacek is offline
post #16 of 19 (permalink) Old 11-05-2012, 03:31 PM Thread Starter
Fuel Pump Issues Continue
Well I managed with much modification to make the fuel pump from High Flow to work, although the Screen/filter wouldn't fit. But got it all together and turn the key, can hear the relay kicking in but not the fuel pump. So I'm thinking can't be ignition, relay is good, fuses are good, there must be something else?
llplacek is offline
post #17 of 19 (permalink) Old 11-07-2012, 03:22 PM Thread Starter
Back up and running
Thanks for all the help and suggestion, but it turned out to be a separate fuse assemble under the seat? Needless to say I check the fuse box and the relay. Oh well new pump, around $100, and much wasted time it is up and running.
llplacek is offline
post #18 of 19 (permalink) Old 11-07-2012, 03:44 PM
Color: Orange SE
I guess this got missed, but, in the future, before buying new parts make sure they are getting juice! If something like this were to happen again, pull the connector off of the pump and test it with a voltage tester. In this case, you'd have found that no combination of key on/off, cranking, etc. caused any voltage to be read, because the fuse was not allowing the juice to flow!
Romans5.8 is offline
post #19 of 19 (permalink) Old 08-25-2015, 10:38 AM
gator21's Avatar
this is the reason I joined this forum. out of the blue, about a month ago, my pump wouldn't kick on. after several on / off cycles of the ign. switch it did. then it would only run on 1 cylinder. I rode it about 6miles before the other cyl. kicked in. no problems for a month or so.. this past week I replaced my battery, went for a nice ride, no problems. the next day I wanted to go for a ride and no more humming of the pump could be heard. fuse was good, relay was clickin when the ign. switch was moved on/off. was hoping for some input from someone, but I couldn't wait any longer. I pulled the tank 1/2 way off, put a test light to the wire plug going to the pump, and its got power with key on. so I took it all the way apart and disassembled the pump assembly. pump in hand , hooked + and - to the battery and its dead. I found a complete assembly on ebay for 109.00. he says it was off a 2001 with 14,000 miles on it . it'll get here in 2days, while I'm at work for 2 weeks. now ive got another mess in the garage that's currently unfinished
gator21 is offline
