Speed-o pegged at 0 - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 01-11-2017, 09:10 AM Thread Starter
Sweet T's Avatar
Year/Make/Model: 2003 Vulcan 1500E Classic
Displacement/CC's: 1500
Color: American Flag tank and front fender. Stock grey/red rear fender
Speed-o pegged at 0
03 VN1500E carb
I was driving down the highway and looked at my speedometer and it was at 0 and the trip-meter and odometer weren't turning.
The fuel gauge is working and all the warning lights are illuminating. Any ideas what would cause that? Wire unplug somewhere? Sensor gone bad?
Sweet T is offline
post #2 of 3 (permalink) Old 01-11-2017, 10:00 AM
Bandit101's Avatar
Year/Make/Model: 2015
Displacement/CC's: 103ci
Color: Black
I believe that your '03 classic has a mechanical driven speedometer. There is a flex cable that connects to a gear drive on the front wheel axel. Normal problem would be a broken drive cable. To check this you will need to remove the speedometer cowl assembly, disconnect the cable from the rear of the speedometer, and you will be able to pull the drive cable out for inspection.
Bandit101 is offline
post #3 of 3 (permalink) Old 01-11-2017, 10:08 AM Thread Starter
Sweet T's Avatar
Thanks Bandit. I'll give that a shot. I will say I've enjoyed the "free miles" since the odometer is stuck.
Sweet T is offline
