Mine is a 2006 and the "fuel filter" is a screen and a non replaceable metal filter inside the tank. The fuel filter is part of the pump assembly and I just ain't gonna pay $600 for a new assembly.
Well i was ridin and it started sputtering and missin like it was trying to die so i pulled in the clutch and gave it alot of throttle and it would go back to fine then few sec later do it again so i did same thing and it did same. I jst bought it guy said it had sit for awhile havent had chance to pull plugs yet but was thinkin something maybe n tank that clogged filter
I also found what i am assuming to be the vent hole for gas tank under the cap clogged with dirt i cleaned it out idk if that could be a cause of the problem or not.
Plugs looked nasty changed them and tried openin gas cap still does same thing my brother asked me where i got gas at i told him said he knew of few people gettin gas there and ended up with some water could that be the cause it did run fine until i had to put gas in it when i bought it had half tank ran fine then i filled up and bout day later is when trouble started
it also has backfired few time idk if that means anything or not
Related Threads
Kawasaki Vulcan Forum
712.7K posts
68K members
Since 2008
