starting problems on my 03 1500 - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 07-05-2011, 10:51 AM Thread Starter
hey i was wondering if any one else had issues firing up there 1500 nomads. i just bought the bike it has 15k miles on it. its a 2003 1500 vulcan nomad
the thing is its a fuel injected bike but when i go to fire it at times i can sit there holding the start button and it will never fire it will turn over and fire once every 3 to 4 rotations but wont start. now if i give it some gas it will fire but then it will stall. i have to baby this thing worse then my carbed bike i use to have. i thought most fuel injected bikes you could just about fire and it would run. no need to baby it till it warmed up.
then the other day when i came to a stop off the highway its idle dropped real low and stalled on me. then it wouldn't fire again. i gave it some throttle and it fired but would stall again so i held the throttle open and just went. the odd thing is its rare for it to happen. it dose not run like this all the time
so i dont know if this is normal or if i might have a fuel injector thats dirty or even if i have a computer issue. im still getting a feel for the world of bikes and this is my first fuel injected bike. thanks for any advice.
ramcharger is offline
post #2 of 10 (permalink) Old 07-05-2011, 01:34 PM
Get you some FI cleaner fluid for starters. I'm not an electrical or fuel whiz, but given the age of the bike it's feasible that the FI's need to be cleaned. Gas is pretty dirty.
Zixxer10R is offline
post #3 of 10 (permalink) Old 07-13-2011, 04:13 PM
Take a look at this:
http://www.gadgetjq.com/tb_cleaning.htm
Post back.
sfair is offline
post #4 of 10 (permalink) Old 07-15-2011, 12:13 PM
Also, take a look at the injectors.
I don't have FI, but my carbs had backed themselves almost all the way out of the air intake and it was taking in way too much air and not enough fuel. Don't know if that will help, not exactly sure how the injectors are positioned.
'04 1500 Classic
National Cycle Heavy Duty Touring 21"
K&N filter
Cobra aftermarket pipes, rejetted
Kury ISO grips
Mustang passenger post cover
Willie and Max Saddlebags
post #5 of 10 (permalink) Old 07-15-2011, 11:16 PM
Injectors give very little trouble, so they should not be touched until all other possibilities are exhausted.
sfair is offline
post #6 of 10 (permalink) Old 07-16-2011, 08:47 AM Thread Starter
Post back.
good advice i will see about doing this ,this week end i did not know about this maint.
post #7 of 10 (permalink) Old 07-25-2011, 07:17 PM Thread Starter
update*** went ahead and tore into the bike cleaned the throttle body out and yeah there was a lot of carbon build up there just used some cleaning spray and q-tips taped together so i could reach back far enough and make it still enough so i could scrub it a bit. thing runs like a champ now.
one odd thing i was going to ask....on the right side of the bike under that TB cover plate when its running at idel there is a pinging sound like a small bell. it sounds like something hitting that cover lightly. this normal?
post #8 of 10 (permalink) Old 07-25-2011, 08:42 PM
Odd noises can be difficult to diagnose on the internet, and I am at a loss for this one.
Anyone else???
sfair is offline
post #9 of 10 (permalink) Old 07-26-2011, 09:17 AM Thread Starter
Anyone else???
it is hard to diagnose it only happens at idle and only every so often. when i am running down the road there is a light nocking sound . not a alarming one and the bike runs fine. i think i might need to run something though the oil next time i change it . im not really worried about it right now but i like to stay on top of things as they pop up instead of ignoring it.
post #10 of 10 (permalink) Old 07-10-2013, 11:37 AM
BOTM Winner, July 2013
Drifter 1500's Avatar
Get you a bottle of Seafoam and put 4 or 5 oz. in the tank and top it off. Take it for a good ride, if the injectors are dirty this should clean them out. That stuff is just short of amazing. Cleaning the TB is good, but you need to clean the internals of the complete fuel system. Some bikes do a lot of sitting and the fuel will varnish up everything it touches. And ethanol is not good either, that stuff destroys aluminum.
Just realized this thread is two years old, my bad.
Drifter 1500 is offline
