1993 Vulcan Clutch Issue - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 03-21-2011, 09:13 AM Thread Starter
Hey all...!
Picked up a 93 Vulcan classic a few months ago. 6800 miles, needed a little work, and best part... FREE! Just got her back from a local shop who re-did the carbs, new tires, salvaged the terribly rusted tank, and full service (fliuds, filters, etc). Runs great now and I'm looking forward to bobbing it next.
I don't know much about hydraulic clutches and had a question. It seems the clutch (line) builds pressure and doesn't engage the gears until almost fully released. I noticed the clutch slipping when laying on the gas a little. I opened the banjo bolt on the resevoir side a little and a small burst or fluid shot out. I tightened the bolt and the clutch performed fine (engaged the gears and no slippage).
Can anyone tell me if this is normal or how to fix it...
Thanks and I look forward to hearing back!!
Brian D
Ft Lauderdale
jibby is offline
post #2 of 7 (permalink) Old 03-21-2011, 10:17 AM
Remove the clutch master cylinder cover, look down in there, and you will see two tiny holes.
Take a nylon bristle and poke it into the holes to make sure they are clear.
If not done already, you should change the fluid in both the braking systems and the clutch system.
sfair is offline
post #3 of 7 (permalink) Old 03-21-2011, 10:32 AM
I had the same concern. I did what sfair stated flushing the
fluid...problem went away. 2003 Vulcan Classic
Johnboy1912 is offline
post #4 of 7 (permalink) Old 03-21-2011, 11:05 AM Thread Starter
Thanks for the quick replies!! Could you give some direction on flushing the clutch fluid? Brakes should be no problem as I have done it on other bikes. Where do I "drain" it, etc??
Thanks again!
Brian D
jibby is offline
post #5 of 7 (permalink) Old 03-21-2011, 01:23 PM
Remove the alternator cover to gain access to the slave cylinder.
Use the same proceedures for flush and bleed as you would for the brakes.
sfair is offline
post #6 of 7 (permalink) Old 03-21-2011, 03:00 PM Thread Starter
And he's off...!
Where might one find the alternator cover? (Just in case, I already know it's probably covering the alternator...) Then, just in case, maybe I should ask where to find the alternator?
Thanks again!!
Brian D
jibby is offline
post #7 of 7 (permalink) Old 03-21-2011, 03:07 PM
Sorry, its that big chrome cover on the left side of the engine beside the shifter.
If you plan to do your own maintenance, the purchase of a service manual would not be a waste of money. Loads of information for the do-it your selfer.
sfair is offline
