thunder air kit install - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 12-03-2012, 02:26 AM Thread Starter
pittdave's Avatar
Does anybody have any pics or the install directions for the Thunder air kit for the 1600 classic?? I would like to add one, but looking at the pics of the kit, where does the air temp sensor go? It looks like the kit just goes over the throttle plate
PD
pittdave is offline
post #2 of 3 (permalink) Old 12-03-2012, 02:06 PM
Pittdave, it bolts straight onto the manifold where the original filter housing was attached. The air temp sensor is bolted to the plate in roughly the same position as it was with the factory setup. An easy install, just make sure u leave the "O" rings on the 2 pipes that come through the plate.
Of the 4 bolts removed from the factory housing that attach it to the manifold, 2 of them get used along with 2 from the kit to reattach the plate to the manifold. The idle air solenoids are no longer used so tape up n cover the wiring, so as no water can get into it, then secure the loose wiring out of the way.
You will also get 2 spacers that go underneath the rear mount of the gas tank so there's enough clearance between the air kit and the bottom of the tank.
Used locktite on all of these bolts/screws.
There's 2 plugs that block off the 2 air idle tubes that extend through the plate, make sure these are fitted after the plate is fitted.
My stepping stone to what I'm riding now.
Suzuki GSX250 '82
Suzuki GSX-R600 '00
Vulcan VN1600 Classic '06
Fitted: tachometer, genuine windshield, K Drive hard bags, upgraded Meanstreak clutch spring with Judges washers, Cobra Speedster Longshots, Dobeck TFI controller, Chucksters air filter plate, Mustang seats with drivers backrest.
Up coming items: volt meter, oil and temp gauges.
Busboy is offline
post #3 of 3 (permalink) Old 03-08-2013, 05:48 PM
Utah Motorcyclist's Avatar
It looks like you installed this on your bike. Can you post some pics?
Jared "Utah Motorcyclist"
VBA#01051
IronButt#37970
VROC#26705
Utah Motorcyclist is offline
