Question big air kit - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 11-15-2012, 09:12 PM Thread Starter
Robs 1600 classic's Avatar
I am thinking about buying the baron big air kit my question is if I get it do I have to get it on a dyno?
Robs 1600 classic is offline
post #2 of 5 (permalink) Old 11-17-2012, 01:03 AM
If your exhaust is still stock, then you won't have to. It's only when you change both stock air cleaner and exhaust that you have to add a fuel processor.
No need for a dyno if its just the air cleaner.
My stepping stone to what I'm riding now.
Suzuki GSX250 '82
Suzuki GSX-R600 '00
Vulcan VN1600 Classic '06
Fitted: tachometer, genuine windshield, K Drive hard bags, upgraded Meanstreak clutch spring with Judges washers, Cobra Speedster Longshots, Dobeck TFI controller, Chucksters air filter plate, Mustang seats with drivers backrest.
Up coming items: volt meter, oil and temp gauges.
Busboy is offline
post #3 of 5 (permalink) Old 11-17-2012, 08:09 PM Thread Starter
I do have Cobra pipes and a cobra processor so I should be all set or will it need to be adjusted?
post #4 of 5 (permalink) Old 11-17-2012, 11:19 PM
Hey Rob. Here's a link to Gadgets page where it's a start for the settings for your bike.
I'm almost finished fitting up the Chucksters air cleaner and fitting a TFI processor to my bike then it's using those base settings on this page, then some minor adjustments as I've fitted an O2 sensor to the rear pipe so as I can get the fuel mixtures right.
http://www.gadgetjq.com/tfi.htm
Suzuki GSX250 '82
Suzuki GSX-R600 '00
Busboy is offline
post #5 of 5 (permalink) Old 11-19-2012, 09:24 AM
I've got the Baron Big Air Kit, Cobra 2 into 1's, and the Cobra fuel processor. I haven't bothered to Dyno it, bike runs like a greased pig just as it is, thanks.
Lunatic is offline
