motor dies upon slowing down - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 11-14-2012, 03:07 PM Thread Starter
Banned
occasionally motor cuts off clean at low RPMs----let cluch out to fire it up....and nothing happens????? hit the starter ....lights up instantly as if nothing was wrong
louichie is offline
post #2 of 7 (permalink) Old 11-15-2012, 11:52 PM
Try this first:
http://www.gadgetjq.com/tb_cleaning.htm
Post back with results.
sfair is offline
post #3 of 7 (permalink) Old 11-17-2012, 01:12 AM
From my experience with my 1600 Louichie, I have to start my bike with the clutch lever pulled in due to the inhibitor switch connected to it.
Check battery connections first. Maybe a dirty or loose cable there.
My stepping stone to what I'm riding now.
Suzuki GSX250 '82
Suzuki GSX-R600 '00
Vulcan VN1600 Classic '06
Fitted: tachometer, genuine windshield, K Drive hard bags, upgraded Meanstreak clutch spring with Judges washers, Cobra Speedster Longshots, Dobeck TFI controller, Chucksters air filter plate, Mustang seats with drivers backrest.
Up coming items: volt meter, oil and temp gauges.
Busboy is offline
post #4 of 7 (permalink) Old 11-25-2012, 07:54 PM
Also, if your idle RPM is set too low it will do that occasionally.
2003 Vulcan 1600 Classic.
Pappyman is offline
post #5 of 7 (permalink) Old 11-30-2012, 11:37 PM
MickeyNew's Avatar
Ditto to what Pappyman said.
2005 Nomad, navy and silver.
MickeyNew is offline
post #6 of 7 (permalink) Old 12-03-2012, 02:18 PM Thread Starter
Banned
thanks to all---good info
louichie is offline
post #7 of 7 (permalink) Old 12-06-2012, 11:13 PM
angelo's Avatar
Those are good first steps for effectiveness / low cost / start with the simple. Should they not work I would consider a flakey battery next.
Cleaning the throttle body makes a very real difference. BTW, I would use q tips on a needle nose dipped in seafoam.
'06 Concours C10
'04 1600 Classic - Gone
PGR #192992
Ride Reports Blog
angelo is offline
