riser install problem - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 11-02-2012, 07:33 PM Thread Starter
pittdave's Avatar
I installed some 2" risers today and now my throttle decel is very slow and sticky. accel seems to be ok but i cant seem to adjust it to where it is smooth
what i am doing wrong
thanks,
PD
pittdave is offline
post #2 of 5 (permalink) Old 11-03-2012, 04:31 AM
Bear2123's Avatar
Either re-route the cables, or replace them with longer ones.
Bear2123 is offline
post #3 of 5 (permalink) Old 11-03-2012, 05:24 AM
hi, with 2 '' risers it's not normal you have a problem with your clutch cable, i have the same on mine with no problem, have you adjust your clutch cable at the handlebars and the cable adjuster in the midle of the cable ? excuse me for my english !!!!!!!!!
photographe83 is offline
post #4 of 5 (permalink) Old 11-03-2012, 07:30 AM
puckoach's Avatar
I have an 06 Nomad.
I don't know what model the OP has.
On a Nomad, the clutch is by fluid, not cable.
That said, his problem is throttle. On my Nomad, when I installed 4 inch up, 2 inch back risers, only the hoses were stretched out to limit. The throttle cables still had plenty of "play". So, I did not try and pull "slack" from any side, of any guides.
So, what model do you have, and did you pull slack, and if so, from where.
Where are your cables now, in front of, or behind the risers ? Are the nuts tight coming out of the hand grip housing ?
The more detail you provide, the better answers the forum members can provide.
06 Kawi Vulcan Nomad - Cobra Lite Bar, Phat II Risers, Vista Cruise, Krusier Kady, Kuryakyn Longhorn Dually Pegs, Mustang w/ Backrest, Vance & Hines Dual Baggers, PC III, Cobra Luggage Rack, Electrical Connection LED R,B, T Conversion, Jay Stephens LED Tail Light, Classic Chaps, Avon Cobra's.
puckoach is offline
post #5 of 5 (permalink) Old 11-03-2012, 10:33 AM Thread Starter
pittdave's Avatar
a-ha.. cruise control was locking too hard and restricting movement
pittdave is offline
