cam chain noise - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 42 (permalink) Old 10-01-2012, 03:59 PM Thread Starter
pittdave's Avatar
cam chain noise
I believe the CCT on my rear cylinder is going. I had the same issue on my 750 and bought the manual ones and they helped a great deal. I don't see any manual ones for the 1600 classic and its only my rear cylinder that has the knock. It is quite evident at the CCT itself, esp using a screwdriver stethoscope. Should I just replace it with a new one and how difficult a procedure is it. The vn750 was a snap, hopefully this will be something I can do. It's a deeper, harder knock sound than the 750 had so I believe the CCT is the culprit as it is worse right at it and not as loud in other areas.
Any thoughts...
PD
pittdave is offline
post #2 of 42 (permalink) Old 10-05-2012, 05:08 PM Thread Starter
pittdave's Avatar
I took her to a local independent cycle shop and the main guy said that it sounds quieter than most and I should just ride. My main issue is the knock is on the rear and not the front. It seems like its the CCT but what else could it be
pittdave is offline
post #3 of 42 (permalink) Old 10-05-2012, 07:05 PM
BOTM Winner, April 2014
Steammaker's Avatar
I was worried to death about this. Its a piece of cake. Get the extensioners from chucksterscustoms .com $35 anticipating the next question & put them on. Be carefull during removal OR just go ahead & get new gaskets too. I was able to get mine OFF with out damage. Go to Gadgets page for step by step instructions OR follow this link, their BOTH good info.
Utah Motorcyclist: How to Install Cam Chain Tensioner Extenders on a Kawasaki Vulcan Nomad
'03 MEANSTREAK
Steammaker is offline
post #4 of 42 (permalink) Old 11-12-2012, 10:05 PM
Kim
where do I find gadgets page? thanks
Kim is offline
post #5 of 42 (permalink) Old 11-13-2012, 06:33 AM
http://www.gadgetjq.com/gadgetsfixitpage.htm
07vulc is offline
post #6 of 42 (permalink) Old 11-13-2012, 11:49 AM
Kim
Thanks 07vulc
Kim is offline
post #7 of 42 (permalink) Old 11-13-2012, 12:47 PM
CRUISERDON's Avatar
It is quite common for the chain to have that loose slapping sound in between the take up points of the tensioner. At times they can sound bad for weeks on end then one day it is quiet till the chain wears a bit more etc. Don't panic yet ! If you install the extenders too soon you can damage the chain runner seriously enough to create a catastrofic situation. The tensioners must be near bottom of stroke before needing them.
If your tensioners are at full extension, then you will be able to use the extenders, BUTT be aware that when the chains wear and get longer, the cam's are being retarded by an equal amount, and the only true fix is to put on new chains, which admittedly is an ordeal requiring top end and side covers removal.
Retarded cams are noticeable and a worn chain can put it back by approx 3 deg. If you check it out you will find that the specs for cams and timing are usually spec'd out to a few Minuit's of a degree !
CRUISER
DON RUSSELL
Aspire Machining
'97 VN1500 91 Cubes Of Custom CLASSIC
original owner
Vance & Hine 2to1
engine, forks, ignition & carb mod's
WebCam cam & rockers hard weld & grind
NEW TOP END, NO LOOKS ALL GO GO
Maxx intake manifold system & super G carb 44mm
CRUISERDON is offline
post #8 of 42 (permalink) Old 11-13-2012, 07:40 PM
Kim
Why would they make extenders then.if you end up with a retraded motor?
Kim is offline
post #9 of 42 (permalink) Old 11-13-2012, 10:37 PM
BOTM Winner, December 2013
big worm's Avatar
Originally Posted by 07vulc View Post
good question. they don't. If you need them, do it.
sorry but you are wrong.... as the chain stretches it does change the cam timing !!!
VN 900 custom "Cheapo-Glide"
Reckless (clone of) fairing
Sony dsx-s100 stereo
Pioneer (for now) 6X9 2-way speakers
Flh hardbags
Mustang "daytripper" seat
Rear lowered 2"
Cobra powerpro HP 2-1
PCIII
Homemade intake with K&N filter
big worm is offline
post #10 of 42 (permalink) Old 11-14-2012, 07:03 AM
big worm's Avatar
i did not dispute weather or not it was a cost effective solution... i just wanted to give the op PROPER information which is timing chain stretch does change the cam timing..
Flh hardbags
Rear lowered 2"
PCIII
big worm is offline
