cam chain noise - Page 4 - Kawasaki Vulcan Forum : Vulcan Forums
post #31 of 42 (permalink) Old 11-19-2012, 10:37 PM
As a general rule, retarding cam timing moves the torque peak down the rpm range, advancing moves it up.
sfair is offline
post #32 of 42 (permalink) Old 11-20-2012, 05:04 AM
Degreaser........ Can u get ur grey matter around this.........
All but 2 types of engines WILL have the cam timing change ever so slightly straight out of the box during its normal operation.........
It's called thermal expansion. As the chain and push rods heat up they will expand, thus changing the cam timing but only a minuscule amount which will not be noticeable.
What are the other 2 engines that are not effected?
My stepping stone to what I'm riding now.
Suzuki GSX250 '82
Suzuki GSX-R600 '00
Vulcan VN1600 Classic '06
Fitted: tachometer, genuine windshield, K Drive hard bags, upgraded Meanstreak clutch spring with Judges washers, Cobra Speedster Longshots, Dobeck TFI controller, Chucksters air filter plate, Mustang seats with drivers backrest.
Up coming items: volt meter, oil and temp gauges.
Busboy is offline
post #33 of 42 (permalink) Old 11-20-2012, 10:39 AM
I know, I know... 2 stroke and Wankel!
Now where is my prize???
sfair is offline
post #34 of 42 (permalink) Old 11-20-2012, 12:09 PM
Well done sfair..... Ur prize is a free round the world trip on ACME Airways.......lol
Lets see if anyone knows wot a Wankel engine is? lol
Suzuki GSX250 '82
Suzuki GSX-R600 '00
Busboy is offline
post #35 of 42 (permalink) Old 11-20-2012, 01:12 PM
CRUISERDON's Avatar
Originally Posted by big worm View Post
good post don.... that combined with post#21 makes it pretty clear....and i am sure you agree that the extenders do work to take up more slack than the OEM ones and will allow many more miles of running with a slight but to most a tolerable loss in performance
Agreed, they do work as intended ! IF !
CRUISER
DON RUSSELL
Aspire Machining
'97 VN1500 91 Cubes Of Custom CLASSIC
original owner
Vance & Hine 2to1
engine, forks, ignition & carb mod's
WebCam cam & rockers hard weld & grind
NEW TOP END, NO LOOKS ALL GO GO
Maxx intake manifold system & super G carb 44mm
CRUISERDON is offline
post #36 of 42 (permalink) Old 11-20-2012, 05:08 PM
BOTM Winner, December 2013
big worm's Avatar
a wankel is also known as a rotary engine....but most will know it as that weird thing under the hood of a mazda rx-7 !!!!
VN 900 custom "Cheapo-Glide"
Reckless (clone of) fairing
Sony dsx-s100 stereo
Pioneer (for now) 6X9 2-way speakers
Flh hardbags
Mustang "daytripper" seat
Rear lowered 2"
Cobra powerpro HP 2-1
PCIII
Homemade intake with K&N filter
big worm is offline
post #37 of 42 (permalink) Old 11-20-2012, 07:37 PM
Well done big worm. U can join sfair on his round the world plane trip. ....lol
Suzuki GSX250 '82
Suzuki GSX-R600 '00
Busboy is offline
post #38 of 42 (permalink) Old 02-16-2013, 08:51 PM
Del
Interesting stuff. Can anyone with real experience tell me how many miles I can expect to get on my very well maintained and tenderly ridden 2002 vn1500 classic before timing chain wear will need to be addressed. Thanks
Del is offline
post #39 of 42 (permalink) Old 02-17-2013, 01:03 PM
CRUISERDON's Avatar
Originally Posted by Del View Post
Interesting stuff. Can anyone with real experience Thanks
Good question, No positive answer, as there are way too many variables that effect the system as a whole. In a bad scenario it could only last 20,000 miles and in a good as much as 100,000 or more. The load on the chain is high on the pins inside the bearings of each roller and also the leading side of sprocket teeth. As the pins and bearings wear, it gets longer (stretch) and puts more load on teeth of sprockets. Its a continuous snow ball.
CRUISER
DON RUSSELL
Aspire Machining
original owner
Vance & Hine 2to1
post #40 of 42 (permalink) Old 02-17-2013, 01:19 PM
Jammin'John's Avatar
How many miles do the cam chains go before the stock tensioner has taken up all the slack it can ?
How long do the sprockets on the cams last ?
If you allow the chain to stretch won't it ruin the cam sprockets ?
What does it cost at the dealer to change the camchain ?
Are there aftermarket camchains available that last longer ?
JJ
'97 Valkyrie Tourer '06 Stratoliner Midnight '09 V2KLT
NOT a member of an organized religion
Jammin'John is offline
