cooling issues 203 vn1600 - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
post #11 of 20 (permalink) Old 09-10-2012, 03:13 PM Thread Starter
Originally Posted by sfair View Post
The other fella is wrong.
Your cooling system is opertating as it should.
i dont see how as the motor heats up it fill the over floow to the point it pisses all over the ground and then when it cools it sucks every thing out of the tank back in the motor
fan works and the radiator is not clogged at all
DeerAssassin is offline
post #12 of 20 (permalink) Old 09-10-2012, 03:46 PM
Oops, you forgot to mention that.
That means it is boiling!!!
Engine cool, squeeze a radiator hose, it should be soft.
Start engine and bring up to temperature. Squeeze same hose, it should be hard.
Post back with results.
sfair is offline
post #13 of 20 (permalink) Old 09-11-2012, 09:02 PM
And a bad radiator cap would cause this.
2003 Mean Streak
Muzzy 2-1 Exhaust
Chuckster Air Intake
PCIII USB
61,000 km
va3ux is offline
post #14 of 20 (permalink) Old 09-11-2012, 09:23 PM
You are correct about that!
sfair is offline
post #15 of 20 (permalink) Old 09-16-2012, 08:14 PM Thread Starter
bad radiator cap
all good now
post #16 of 20 (permalink) Old 11-01-2012, 06:04 AM
fans run
Jap bikes like to run cool so fans do run.
Tweaser is offline
post #17 of 20 (permalink) Old 11-01-2012, 06:44 AM
Your cooling system is working fine.
rreyesjr1952 is offline
post #18 of 20 (permalink) Old 11-02-2012, 05:54 PM
Pretzel's Avatar
So if the overflow shows full when hot, but doesn't suck any coolant in when the bike cools...
very low coolant in the radiator?
air bubble?
something else?
LED Run/Turn/Brake
Vance and Hines Duals
Dobeck TFI
Vista throttle lock
Pretzel is offline
post #19 of 20 (permalink) Old 11-03-2012, 10:41 AM
Leak somewhere on the pressure side of the system...cap, hose, head gasket, etc.
Or the overflow tank hose is not connected.
sfair is offline
post #20 of 20 (permalink) Old 11-03-2012, 06:46 PM
Pretzel's Avatar
Ordering a Dobeck TFI this week, will pull the tank to install and check it all. Thx!
Sent from my iPhone using Motorcycle.com App
LED Run/Turn/Brake
Dobeck TFI
Vista throttle lock
Pretzel is offline
