Hi guys,
I will be changing the plugs on my vn1600 this week and want to make sure im doing it right. I read the service manual and it seems pretty straight forward, remove old ones, insert new ones, tighten to 13ft-lb. I also read on some sites that I should insert some oil into the hole before putting the new plug in...is this recommended? what is the purpose? should I do it, or just replace the plugs?
eggrs,, always rember, ritey titey, leffy looser..
put some spark plug thread "anti sieze" aka silver schitt on them plugs b4.. always start yor plugs by hand and never force them or cross thread them back in. oh yeah, chek/set the gap firstest.
some put fog type oil spray in their cylinders b4 they put them up for the winter. not required if yor gonna fire it up and ride it.
when, where you get yor plugs. they will have (wire) gap tool and anti seize stuff. chek yor owners manual for proper gap setting.
I would bet yor v16 came stock with iridium plugs. they are good for 50k miles or more. some fellas like to change things because they can. ok. but it is not necessary. I changed mine at 50k and they still looked like new.
Irridium plugs are standard in most newer motors. my truck they were good at 100k. but I changed anyway. poncho
brown/tan = good. white = too lean, too hot. black = too rich, too cold.
Lotta people say the gap should be between .031 and .036 online... but the service manual says this:
Measure the gap [D] with a wire-type thickness gauge. If the gap is incorrect, carefully bend the side electrode with a tool to obtain the correct gap. Spark Plug Gap: 0.8 ∼ 0.9 mm (0.03 ∼ 0.03 in.)
I'm not sure what to make of that... what is the correct gap using the gap tool for a Nomad 1600 2006? I was gonna go with .034 but the manual is calling for 0.03 ∼ 0.03 in.
Related Threads
Kawasaki Vulcan Forum
712.7K posts
67.8K members
Since 2008
