In the market for a Nomad and I rode an 08 1600 Nomad the other day. It was my first time on a 1600.
I liked it except at 60mph+, I was experiencing helmet buffeting. The windshield was on the lowest setting. I'm 5'6".
I've never had a bike with a big windshield before. When I look out in front of the bike, am I supposed to see through the windshield or completely over it?
The top of the windshield should meet at about your chin, i too feel buffeting on windy days, but we're not cagers either, some of it is expected.....ride on....
I had that problem and as Buffalobob said ,you need lowers. When riding, put your hand by the front of the tank and you will feel the wind coming up. I installed Edmonds Lowers and the issue went away.
Yep. Lowers I was having the same issue. Made me some lowers out of plexiglass (lexan) and buffeting is gone. Good thing about cutting your own is you can make any size or design you want.
Yes, the lowers are attached to the forks. The after market lowers are much bigger. Here is a picture of my lowers. I was putting on new tires at the time.
Best for me is to have the top of the windshield set at my nose. Then make sure the lower windshield is down close to the headlamp. Then of course taller lowers help as well. These are homemade.
If the shield is to high, you can actually trim the top. Make a cardboard copy of the top of shield. Top should be level with your nose. Measure how much you wish to trim off. Trace along the cardboard. Use a fine blade and go slowly. sand until smooth.
This is how I cut my lowers. Used a scrolling jigsaw blade. Used a belt sander with 300 grit sand paper (coulda gone with finer for clearer edges) and worked out great. I tried to heat the edges to make em nice and pretty, but when I did it would melt too much and ended up being thicker on the edge and to me-didn't look good. Glad I tried on scrap first.
Related Threads
Kawasaki Vulcan Forum
712.7K posts
67.9K members
Since 2008
