Headlight not always coming on - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 12-19-2012, 10:56 AM Thread Starter
drasm22's Avatar
Send a message via Skype™ to drasm22
My 2008 VN2000 LT Classic is suffering from SHAS (Sporadic Headlight Amnesia Syndrome).
Sometimes (50%) the headlight fails to come on when starting the bike. If I turn the ignition off then restart it OR very quickly turn the ignition switch over to "Park" then quickly back to "Run", the light will come on. Most of the time doing the "Run / Park / Run" method only results in a stalled bike that doesn't want to easily restart. It also results in the headlight coming on and staying ON while the bike isn't running.
I first became aware of the problem after taking out a swooping finch at about 60 mph with my left turn signal. It shattered the signal lens which I easily replaced; however, that's when I noticed that the headlight didn't come on. I have no idea if the two events are connected or if the headlight has been doing this for awhile; but I never noticed the problem until after hitting the finch.
Has anyone else experienced what I'm describing?
drasm22 is offline
post #2 of 10 (permalink) Old 12-19-2012, 11:29 AM
V2KCruiser's Avatar
I had the same thing happen on my V2K a few years ago. It was a bad headlight relay in the relay assembly box located below the battery box (see part #27002 in below diagram). This box contains relays for the starter circuit, ECU, fuel pump, headlight and fan. If any one of these relays fails you have to replace the whole relay assembly box.
2006 Vulcan 2000 Classic
V2KCruiser is offline
post #3 of 10 (permalink) Old 12-19-2012, 04:22 PM
ophidia's Avatar
Same thing happened to me, and it was the relay box.
2006 V2K Limited
ophidia is offline
post #4 of 10 (permalink) Old 12-20-2012, 09:39 AM
Jammin'John's Avatar
How expensive is that box ?
It relays starter circuit, ECU, fuel pump, headlight and fan,5 items ?
You can't just fix ONE of the items,say the fuel pump,but you have to replace everything ?
JJ
'97 Valkyrie Tourer '06 Stratoliner Midnight '09 V2KLT
NOT a member of an organized religion
Jammin'John is offline
post #5 of 10 (permalink) Old 12-20-2012, 10:47 AM
V2KCruiser's Avatar
You can't just fix ONE of the items,say the fuel pump,but you have to replace everything ? JJ
CheapCycleParts.com is selling it for $85.25:
Kawasaki RELAY-ASSY
It's an all or nothing replacement. If any one of the internal relays fails you have to replace the entire relay box.
post #6 of 10 (permalink) Old 12-20-2012, 07:18 PM
That's NOT cool !
JJ
post #7 of 10 (permalink) Old 12-21-2012, 11:56 AM
R_W_B's Avatar
Yea the schematic shows them all wired together. I.e. the power to the headlight relay can be broken by the starter relay, etc etc.
Seems they could of still sold each separate though. I think it might have something to do with whether or not the current protection diodes are in the box or in the relays.
R_W_B is offline
post #8 of 10 (permalink) Old 12-21-2012, 12:15 PM
aarrgghh !
JJ
post #9 of 10 (permalink) Old 12-29-2012, 09:41 AM Thread Starter
drasm22's Avatar
Thanks for the responses everyone!
drasm22 is offline
post #10 of 10 (permalink) Old 01-04-2013, 11:05 PM
I have only ever had it do this on start up twice but once it was running no problems. What I did have a few weeks ago was the fan not kicking in and so one very hot bike. It turns out it was a bit of corrosion in the relay probably from washing the bike. It happens over time. Maybe check the relay and see if this is what the problem is.
Cheers and Beers.
Bob
Popeye is offline
