Winshield Angle - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
post #11 of 29 (permalink) Old 12-05-2012, 05:17 PM
Hockeyref's Avatar
I matched the windshield angle with the forks on my '06 Classic LT, worked great in that the buffeting was less and the windshield moved down to jsut the right height for me (I'm 6 feet tall). I also have Kuryakyn lowers which also helped, still get some buffeting at my upper chest/lower face area. Anyone got any suggestions on that? If I hold my arm in front of me as if to lean down with my elbow on the gas tank the buffeting disappears. I am thinking perhaps a fairing but my better half does not like the look....
2006 V2K Classic LT Black/Chrome
Lots of chrome goodies, sagebrush engine guard chaps for cold days in Manitoba, Rumble Road speakers, Garmin gps, tank bib, modified seat, Ohlins rear shock - best investment ever!!, locking saddlebags, Kuryakyn luggage, brake-away cruise control, and more stuff every year.
Hockeyref is offline
post #12 of 29 (permalink) Old 12-05-2012, 08:10 PM
Pearhead's Avatar
I built my own lowers and leaned the windshield back to match the fork angle, made a big difference in the buffeting.
I am currently on my 3rd set of lowers. I have been experimenting with
different lengths,widths and angles.
I have found that length and angle has more effect than width in lessening the buffeting.
Currently working on the 4th, and hopefully last, set. which I will not be able to test tell spring
And I know Smed, Pics will be posted than......
2009 VN2000 LT.
XXX Chopper intake.
Freedom Performance
Sharp Curves.
TFI Fuel Contollor.
Custom Lowers.
Custom Luggage Rack.
Windscreen Leaned Back.
Avon Cobra, Front
Darkside:Yokohoma Envigor,205/60
33 Tooth front Pulley
Pearhead is offline
post #13 of 29 (permalink) Old 12-05-2012, 10:19 PM
Wild_Bill's Avatar
Post some pictures with measurements and I'll test them for you. We are able to still ride in south Ga. I've had my windshield angled back for a while but I'm still getting the up your nose that only the proper lowers can cure. I've got enough 1/8 " plexiglas to make 10 pairs just lying around.
Wild_Bill is offline
post #14 of 29 (permalink) Old 12-06-2012, 02:06 PM
Dadinator's Avatar
Originally Posted by SWVA_08V2k View Post
BTW how tall are you?
Approx. 5' 10"
2008 V2K Classic LT.
Ride Long and Prosper
Dadinator is offline
post #15 of 29 (permalink) Old 12-06-2012, 02:54 PM Thread Starter
SWVA_08V2k's Avatar
Originally Posted by 2K4V2K View Post
I believe there was only one model in the introductory year. That was the vn2000a. It is neither the classic nor the custom.
I looked at them today and saw that they called for a different part number for the Classic, which is what I have.
Originally Posted by Dadinator View Post
Approx. 5' 10"
That actually give me a good idea of how it will line up with me since I am 6'.
SWVA_08V2k is offline
post #16 of 29 (permalink) Old 12-06-2012, 07:34 PM
Pearhead's Avatar
4X10 currently.pics attached.
Going to try 3X14 on the next set.
Sent from my SAMSUNG-SGH-I577 using Motorcycle.com Free App
ID:	14501   Click image for larger version
2009 VN2000 LT.
XXX Chopper intake.
Freedom Performance
Sharp Curves.
TFI Fuel Contollor.
Custom Lowers.
Avon Cobra, Front
Pearhead is offline
post #17 of 29 (permalink) Old 12-07-2012, 07:47 AM Thread Starter
SWVA_08V2k's Avatar
Ok, Finally here are some Pics of the difference is looks.
Before
After
Before
After
Before
After
post #18 of 29 (permalink) Old 12-07-2012, 08:08 AM
Dadinator's Avatar
U might try lowering it and see what that does for the buffeting. The lower setting helps the updraft around the tank. Not as much as lowers mind you, but it does help.
post #19 of 29 (permalink) Old 12-07-2012, 08:12 AM Thread Starter
SWVA_08V2k's Avatar
I may do that. I have not had an opportunity to take it for a test run yet.
post #20 of 29 (permalink) Old 12-07-2012, 01:42 PM
bigbob1944's Avatar
windshield lowers
That is pretty well the same thing that I done except I left my windshield up high because with it at the factory angle I got blasted in the head with it at its lowest position. Also I just drilled a hole. I did not cut mine out in to an "L" shape. I also saw later in that thread where someone used some HD lowers. I may have to look in to that if changing the angle is not enough. BTW how tall are you?
I used Memphis shades lower mounting hard ware, and made my one lowers out of lexon. The ones you buy are to small. I custom make them to each bike.
bigbob1944 is offline
