pipes - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 15 (permalink) Old 11-27-2012, 06:25 AM Thread Starter
obrienc's Avatar
pipes
i am putting on vance and hines powershots on 2007 v2k classic
do i need a fuel management system or can use as is?
obrienc is offline
post #2 of 15 (permalink) Old 11-27-2012, 08:56 AM
smedlin's Avatar
meh, you will hear different answers and different reasons.
Are you running stock air filter?
If your just using stock filter, you probably don't need a fuel management doohickey.
You may get some popping on dec though, since your back pressure probably won't be correct.
Yes, I'm a Chrome Whore.
2004 Vulcan 2000
smedlin is online now
post #3 of 15 (permalink) Old 11-29-2012, 10:46 PM
The Heater's Avatar
All engines are engineered to run with the system that comes on the bike. Once you change it, the power curve on a dynomometer will show it has changed. While you may not notice any big difference in how you ride your bike, I guarantee you have lost torque and horsepower with any aftermarket system. The only way to fix it is to take the bike to a shop with a dynomometer and have them see where you have drops in the curve and then try to tune it out by programming the ECU (whether it is the stock or an aftermarket ECU). Anyone who thinks they have "more power" with loud pipes is dreaming. This is a case of where perception becomes the person's reality. It sounds loud so they think it has more power. It just isn't the case.
The Heater is offline
post #4 of 15 (permalink) Old 11-30-2012, 05:58 AM
2K FANATIC's Avatar
06 07 run leaner than all other models if it pops on decel with ASV blocked you will need a Cobra or I prefer the Teclusion (TFI).
Bare
2K FANATIC is offline
post #5 of 15 (permalink) Old 11-30-2012, 05:59 AM Thread Starter
obrienc's Avatar
pipes
thanks for the information
i will order a fuel management system and have installed
is there a system that is plugin and it will automatic adjust fuel?
obrienc is offline
post #6 of 15 (permalink) Old 11-30-2012, 06:34 AM
2K FANATIC's Avatar
Be sure to buy plug and play read the instructions Cobra 3 pods set at 3 5 0
Techlusion 4 pods set at 3 2.30 2 4 that is a good starting point.
Bare
post #7 of 15 (permalink) Old 11-30-2012, 07:56 AM
101stFister's Avatar
ive got an 07 with the powershots, BAK, and chip. i run without baffles and only get an occasional pop, unless i want to wake up the cagers around me.
2007 Vulcan 2000 LT
BAK
V&H Powershots
computer thingy
May the road rise to meet you and the wind always be at your back
101stFister is offline
post #8 of 15 (permalink) Old 11-30-2012, 08:04 AM
2K FANATIC's Avatar
FACT... V2K Without baffles..power loss is significant if you prefer the baffleless sound at least install http://www.bigcitythunder.com/
Bare
post #9 of 15 (permalink) Old 11-30-2012, 08:07 AM
im sure there is a loss of power, but this thing is such a tractor i dont really notice. ive been hit twice this year and will sacrifice a little power to wake up the cagers. i bought the bike used and had a beast of a time pulling the baffles, so im not even sure if i could get the BCT baffles in. they do sound nice though
2007 Vulcan 2000 LT
BAK
V&H Powershots
computer thingy
post #10 of 15 (permalink) Old 11-30-2012, 09:42 AM
bigsarge2012's Avatar
some dyno charts from various set ups. Smedlin you got one with the freedom pipes?
http://www.rogueownersgroup.com/RogueDynos.aspx
bigsarge2012 is offline
