Checking fluid..... - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 15 (permalink) Old 11-09-2012, 06:16 PM Thread Starter
Send a message via AIM to jmorris
Checking fluid.....
I've just bought an '09 Classic LT 2K. I've had a 1600 Classic so not much different on certain things, but yet there's a WORLD of difference on other things. I cannot, for the F'ing life of me, figure out HOW to check the fluid level for the radiator. I've found the reserve tank, and the side tube, but I cannot believe that that's the tube to check. Afraid to dump too much in there for fear it'll overflow and cause even more trouble. Also, it has an FI200 Cobra processor. I'm having a helluva time getting that into sync also. I've plugged up my 2 air valves from and into the air cleaner, and that has seemed to help somewhat on the back-lash. But it still pops and backfires on decel and also during shifts. I don't mind too much but this seems a bit to the extreme. I've got the pots set at 3 5 0 which is default. I bought the bike with a Cobra 2 into 1 exhaust and no air intake mod. Any and all help would be appreciated. Thanks in advance.
Mike!!
jmorris is offline
post #2 of 15 (permalink) Old 11-09-2012, 09:44 PM
smedlin's Avatar
yeppers, that's the little window for the radiator fluid.
Yes, I'm a Chrome Whore.
2004 Vulcan 2000
smedlin is offline
post #3 of 15 (permalink) Old 11-09-2012, 09:52 PM
whoaru99's Avatar
Yup, and the popping? Well, be sure the pipe flange nuts are tight and that's about it. Mine pops a lot too if I let it but by management of the throttle the loud pops are quite avoidable without a fuel box.
whoaru99 is offline
post #4 of 15 (permalink) Old 11-09-2012, 10:00 PM
Hockeyref's Avatar
My coolant sight tube has been useless since day one, I just use a thin piece of rubber tubing and use that to check the fluid level in the coolant tank - works great. Don't worry if you overfill a little bit, the overflow tank cap is designed to let some out if necessary and there is also an overflow drain tube. The rad cap is under the tank and you have to remove the tank to get to it - kind of a pain. In regards to the fuel processor, etc. sorry I can't help mine has stock intake with just a K & N air filter.
2006 V2K Classic LT Black/Chrome
Lots of chrome goodies, sagebrush engine guard chaps for cold days in Manitoba, Rumble Road speakers, Garmin gps, tank bib, modified seat, Ohlins rear shock - best investment ever!!, locking saddlebags, Kuryakyn luggage, brake-away cruise control, and more stuff every year.
Hockeyref is offline
post #5 of 15 (permalink) Old 11-09-2012, 10:13 PM
smedlin's Avatar
Btw, the tank is super easy to take off.
2004 Vulcan 2000
smedlin is offline
post #6 of 15 (permalink) Old 11-10-2012, 01:18 PM
I have a 09 lt also and have changed pipes (3" hk) and have some popping on decel, after checking all the fixables it still does it not real bad but...I am not overly happy with the pipes and am thinking bout putting the stocks back on but the wife likes the loud pipes so.....time will tell
wttn water is offline
post #7 of 15 (permalink) Old 11-10-2012, 03:07 PM
smedlin's Avatar
The popping means your probably running to rich of fuel now. Some popping is ok. Personally, I like when mine does that
(might also want to check your gasket and bolt's on the new pipes, make sure they are still tight and not leaking)
Are you running stock air intake?
2004 Vulcan 2000
smedlin is offline
post #8 of 15 (permalink) Old 11-10-2012, 03:16 PM
yep i have stock air, thought about a air kit and controler with auto tune but the funds just say its not in the cards now
post #9 of 15 (permalink) Old 11-10-2012, 05:08 PM
bigsarge2012's Avatar
Plugging the top of my cylinders removed most the pop on decal , then setting the values to zero at 0 throttle on my PCIII map took care of the rest. Now it sounds perfect. I would recommend finding one for cheap on ebay or Craigslist.
bigsarge2012 is offline
post #10 of 15 (permalink) Old 11-10-2012, 08:09 PM
Hey Mike, if you are at 3-5-0 with your Fi2000r and have stock air chances are really good that you're running too rich. Do like I did and pull a plug then you will know. I have the Cobra 2/1 HP Powerpro exhaust as well. Some of that popping is just the character of that exhaust system. You can disconnect the fuel chip and run fine without it.
TB2000 is offline
