Strange Noise - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
post #11 of 22 (permalink) Old 10-23-2012, 08:16 AM
rkd2.3's Avatar
Given the limited info available without actually HEARING the noise first hand, I might be inclined to suspect the dampener on the primary drive ! Its job is to smooth out the intense power pulses of the V2K engine & then pass the power on via a chain similar to a automotive timing chain , to the trans.
Just my logic, but if the noise sounds "internal" , I am betting on the primary drive system. It all located behind the leftside engine case chromecover.
This doeesnt necessarily mean that there is an actual problem within it, but it could be the source of an" audible reaction" to a clutch issue as well.
http://www.motorcyclecruiser.com/new.../photo_21.html
08 V2K Classic
plus
04 Vulcan 2000
Old school turbocharged VW trike
VROC # 7003
ROG # 175
RKMC
rkd2.3 is offline
post #12 of 22 (permalink) Old 10-23-2012, 01:23 PM Thread Starter
I was wondering if there was some kind of tensioner , etc. with the primary drive. That would also explain a slight driveline lash that I had noticed recently. I guess I'll pop the cover and see what I find.
pete04 is offline
post #13 of 22 (permalink) Old 10-23-2012, 03:01 PM
smedlin's Avatar
You should check, just to make sure your 04 has the correct hub/bearings.
I know there is a way, but can't remember how to tell them apart...
Yes, I'm a Chrome Whore.
2004 Vulcan 2000
smedlin is offline
post #14 of 22 (permalink) Old 10-23-2012, 04:33 PM
V2KCruiser's Avatar
The '06 and up hubs have a bigger, beefier center bearing in them. In the below pics the '04 hub is on the left and the later model hub is on the right:
2006 Vulcan 2000 Classic
V2KCruiser is offline
post #15 of 22 (permalink) Old 11-04-2012, 08:28 AM
Wild_Bill's Avatar
Pete 04
Pete 04, what was the problem??
Wild_Bill is offline
post #16 of 22 (permalink) Old 11-04-2012, 08:56 AM
smedlin's Avatar
Aye, I'm curious as well.
2004 Vulcan 2000
smedlin is offline
post #17 of 22 (permalink) Old 11-04-2012, 08:57 AM
smedlin's Avatar
Is there a way to tell which one I have, without taking the hub out of the wheel, and not having a new one to compare it to?
2004 Vulcan 2000
smedlin is offline
post #18 of 22 (permalink) Old 11-04-2012, 11:13 AM
V2KCruiser's Avatar
Sorry, I don't know. I only posted pics from someone else who replaced the hub.
post #19 of 22 (permalink) Old 11-11-2012, 05:51 PM Thread Starter
I still can not determine where it is coming from or what it is. It seems to have disappeared for a while, but now it is back. Definitely not rear hub bearings or output shaft problem.
pete04 is offline
post #20 of 22 (permalink) Old 11-12-2012, 01:33 PM
You're probably right, I just want to be clear, though.
When my rear hub went, it made an occasional lightish "thunk"ing sound, not the grinding you'd expect to hear from a failing bearing. A quick lift on the hoist and a few spins of the rear wheel and I knew it was from the rear axle area, probably the bearing since this was a known issue and my bike had right around 15K miles on it. When I took it to the shop, the bearing came out in pieces. Luckily I had the parts pre-ordered.
Bill Braske is offline
