Rear brake lever adjustment - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 02-15-2017, 09:08 AM Thread Starter
AW139mech's Avatar
Year/Make/Model: 2017 Vulcan S
Displacement/CC's: 650
Color: Gray
Hi all
I just received my 2017 Vulcan S. it came with the mid reach seat and the foot pegs in the rear position. everything is good except i would like it if the rear brake pedal was a little closer to the seat. Does anyone know if there is enough adjustment in the linkage to move it much? I've only had a quick glance and i couldn't determine how much adjustment was available, anyone tried this?
I'm 5'3" everything else is good I just wish the rear brake was engaging sooner in the pedals travel.
Thanks guys
AW139mech is offline
post #2 of 5 (permalink) Old 02-15-2017, 11:17 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
on my 800, the rear brake pedal has an adjustable bolt to increase/decrease pedal travel
Thunder Mfg teardrop 40's K&N 170MJ 48PJ 2.75turns DynoJet Needle DNO106 2nd notch V&H Cruzers Aeromach risers Michelin Commander IIs Shell Rotella 5w40 Wix 51358 17T/40 Sprockets
btom is offline
post #3 of 5 (permalink) Old 02-16-2017, 05:32 AM Thread Starter
AW139mech's Avatar
Color: Gray
Found it
There is a link between the pedal and the master cylinder that can be adjusted a little. I'm going to experiment and see how far i can go.
post #4 of 5 (permalink) Old 02-16-2017, 05:48 AM
Year/Make/Model: 2015 Kawasaki Vulcan S
The pedal's not really designed to be adjusted.
The rod end clevis for the rear brake cylinder can be adjusted a few millimetres but anything more will mess with the brake light switch above it.
They're more or less set and forget. That's why the whole footrest and brake pedal assembly moves as a single unit across the the 3 reach settings.
Cpt.Evil is offline
post #5 of 5 (permalink) Old 02-16-2017, 05:53 AM Thread Starter
AW139mech's Avatar
Color: Gray
Thanks for the tip. I'll check that out. I remember seeing in the owners manual about adjusting the brake switch.
