Foot peg position - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
 5Likes
post #11 of 21 (permalink) Old 01-10-2017, 06:44 PM
MARINE's Avatar
Year/Make/Model: 2016 Kawaski Vulcan S ABS SE
Displacement/CC's: 649cc
Color: Blue
The standard is mid reach as factory default. I replaced the pegs with floorboards. Happy as can be.
MARINE is offline
post #12 of 21 (permalink) Old 01-10-2017, 08:34 PM Thread Starter
Year/Make/Model: '15 kawasaki vulcan S
Displacement/CC's: 650
Color: 85326
Marine, what floorboards did you use. I think that's gonna be my first mod.
Sent from my VS985 4G using Tapatalk
Phatmanswingin is offline
post #13 of 21 (permalink) Old 01-10-2017, 09:30 PM
MARINE's Avatar
Color: Blue
the Kuryakyn floorboards (4357) using the Kuryakyn splined adaptors (8813) they're a few posts in here. Just search keyword floorboards. I cannot paste a link on mobile now. Don't use what manufacturer says on their website for the spline adapter. Read the posts easy as pie.
MARINE is offline
post #14 of 21 (permalink) Old 01-31-2017, 05:16 AM
blackcow0212's Avatar
Year/Make/Model: 2015 Kawasaki Vulcan S ABS
Color: Urban White
boots get stuck between foot peg and shifter
Hey guys, just went out for my first ride last night, it was kinda scary at first (trying to remember what I learned in MSF course ~7 years ago) but it quickly became fun
One issue I noticed while riding is that my boots either get stuck between the foot peg and the shifter, or I have trouble getting my foot under the shifter to shift up. This is probably partly due to the fact that I'm not use to shifting, but I feel like the gap is actually a bit too narrow (at least for the boots I have). I believe the foot pegs are set up with the regular mid-reach position, is there anyway I can increase the gap between the foot peg and the shifter? or should i just get a pair of boots with thinner/flatter toe so it will fit between peg and shifter?
thanks in advance! Can't wait to go out and ride again tomorrow night!
1st bike - 2015 Kawasaki Vulcan S ABS - Urban White
blackcow0212 is offline
post #15 of 21 (permalink) Old 01-31-2017, 07:31 AM
telstokes's Avatar
Year/Make/Model: 2016 Vulcan S
Displacement/CC's: 650CC
Color: Metallic Matte Carbon Gray
If you adjust the shift rod it will help.
Start loosening the lock nuts then you can turn the rod to adjust where the shifter sits.
telstokes is offline
post #16 of 21 (permalink) Old 01-31-2017, 07:34 AM
telstokes's Avatar
post #17 of 21 (permalink) Old 01-31-2017, 07:35 AM
telstokes's Avatar
If you can see the little silver nuts in this picture if you back them off you can then turn the whole rod.
post #18 of 21 (permalink) Old 01-31-2017, 11:34 AM
FurEBear's Avatar
Color: Flat Black
FYI...one nut is lefthand thread and the other is righthand....that is how the rod adjusts...turn one way it gets shorter...the other it gets longer.....
It is not about the destination, but how you get there.
FurEBear is online now
post #19 of 21 (permalink) Old 01-31-2017, 12:50 PM
Newfiezedder's Avatar
Year/Make/Model: 2015/Kawasaki/Vulcan S
Color: Flat Ebony aka black
I just order the reduced and extended reach rods, figured for $20 lets play around see if I like either one better than the standard.
GR
Newfiezedder is offline
post #20 of 21 (permalink) Old 01-31-2017, 07:39 PM
Color: Urban White
Thanks for the suggestion, I'll give it a try tonight.
Does anyone know if I can use the reduced-reach shift rod with the foot peg at mid-reach position? I'm just shy of 5'7, and I think the recommended height for mid-reach start from 5'7"...should I go with the reduced-reach setup? anyone on here is about 5'7 and can share which -reach they like better?
thanks
