One of the mods I'm doing to make more power available for accessories is changing out the existing incandescent OEM turn signal lamps with LEDs. Note I said lamps, not the turn signal fixtures.
Obviously the turn signal relay had to be changed out (I used the Competition Werkes MPH-U2R) to deal with the 'fast flash' syndrome...easy job.(See Post #3 in this thread for an explanation of fast flash)
Next came the selection of a replacement lamp; the front and rear turn signal lamps are Philips 10293 RY 10W NA (amber) with a BAU15s base. I wanted an equivalent amber LED lamp with similar or superior lumen output and much less wattage (on the order of 2-3W/lamp). I bought some thru eBay and they arrived today:
They are a bit longer than the stock lamps, but still fit under the lenses. At $7 per pair I figured I'd give them a try...make sure you measure and don't get lamps that are too long!
They appear to have similar brightness to stock OEM lamps; the video below shows the results...one of the lamps (RIGHT side of the screen) is OEM incandescent, the other LED:
https://vimeo.com/179816312
One thing I noticed...the first time I plugged one in it flashed, but only at about 1/10 the brightness of the OEM lamp....very odd. So I removed it, then re-inserted it while the emergency flasher was running. Upon placing the lamp in the base it shone brightly, but when rotating it to lock it went to a very dim level of flashing. [emoji848]
I checked the connections to the socket, did some additional checking and discovered THIS:
It appears that the lamp manufacturer is so proud of their product they put a small sticker on each lamp with their name...this sticker is just enough of an insulator (the way Kawasaki constructs the Vulcan S socket it does not have 360-degree contact with the side) to reduce the voltage/current to the lamp.:
Detail of plastic lamp socket with side contact strip.
Peel the sticker off the lamp and it acts normally. Geez, what a science fair project [emoji849].
Time will tell how this new relay/lamp setup holds up to the abuses of Pacific NW roads and rain...stay tuned.
